Nathan Valdez Posted May 14, 2016 Report Share Posted May 14, 2016 As you all may know, I recently bought a Bosch 10.8v impact. I have 1 bosch pocket driver - the 12 volt. The batteries are identical except for the slight different voltage. Will it damage the tool or the battery if I were to use them interchangeably? #TIACREW Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted May 14, 2016 Report Share Posted May 14, 2016 10.8 = 12v 12 volt is the voltage for the packs not under load, once a load is applied they drop to 10.8 Jimbo Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Nathan Valdez Posted May 14, 2016 Author Report Share Posted May 14, 2016 So it's safe? Quote Link to comment Share on other sites More sharing options...
BMack37 Posted May 14, 2016 Report Share Posted May 14, 2016 TBH, it would be fine if you put an actual 18v battery on it. The brushes would wear out faster but electric motors are robust as hell. ...but yeah, these 12v batteries under load drop down to 10.8ish volts. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted May 14, 2016 Report Share Posted May 14, 2016 So it's safe? Yes, same battery Bosch just changed their labeling in the US to 12v Quote Link to comment Share on other sites More sharing options...
Fazzman Posted May 14, 2016 Report Share Posted May 14, 2016 its the same dude, 12v max = 10.8 legit volts Quote Link to comment Share on other sites More sharing options...
Nathan Valdez Posted May 15, 2016 Author Report Share Posted May 15, 2016 Thanks my dudes!!! I appreciate ya #TIACREW 2 Quote Link to comment Share on other sites More sharing options...
