comp56 Posted August 8, 2016 Report Share Posted August 8, 2016 ok so I have being using my 12- 1/2" planer for several hundreds of board feet of stock although this model is a cheaper type compared to others it has served me quite well.....never had any issues with all kinds of hardwoods and such. However this morning as I running some Black Ash though it I hear a bang and the feed stops........shut it down and remove stock ......hmmm so I investigate and find out a chain has popped a link.......(I didn't take pics until what you see) anyway as what I could tell the chain link didn't brake it only came apart and dropped the chain so with my trusty metal bench vise I was able to replace pin back into link and pien end..... I was able to connect chain and then put it back on sprocket because the sprocket could be removed easily......I will post some more pics as I get it back together..... ok drive rollers installed with proper tension and chain on both sprockets....success.....just have to re-assemble everything 2 Quote Link to comment Share on other sites More sharing options...
DR99 Posted August 8, 2016 Report Share Posted August 8, 2016 Is that the Ryobi Planner? Quote Link to comment Share on other sites More sharing options...
comp56 Posted August 8, 2016 Author Report Share Posted August 8, 2016 no it is our Canadian Tire brand Mastercraft Quote Link to comment Share on other sites More sharing options...
DR99 Posted August 8, 2016 Report Share Posted August 8, 2016 The color looks exactly like the old Ryobi blue Quote Link to comment Share on other sites More sharing options...
comp56 Posted August 9, 2016 Author Report Share Posted August 9, 2016 without looking close to a Ryobi it could be same but with different names... Quote Link to comment Share on other sites More sharing options...
comp56 Posted August 9, 2016 Author Report Share Posted August 9, 2016 happy to report the planer is completely assembled and is once again planing wood..... 1 Quote Link to comment Share on other sites More sharing options...
Logan Posted August 9, 2016 Report Share Posted August 9, 2016 It's nice that it was a quick repair Quote Link to comment Share on other sites More sharing options...
LarryS Posted August 10, 2016 Report Share Posted August 10, 2016 Glad to hear that you got it running again Quote Link to comment Share on other sites More sharing options...
Grant Posted August 2, 2020 Report Share Posted August 2, 2020 I appreciate your post, I just had the same problem on my identical planer. How hard to turn are your feed-in rollers? Mine seem stiff and I wonder if that contributed to the chain breaking. Also I can't turn the drive sprocket by hand, but I am assuming that that is because there is a gearbox between that sprocket and the motor. Quote Link to comment Share on other sites More sharing options...
