Sign fabrication projects
Figured I'd start a thread sharing some pics of builds I'm doing.  I'll try to get pics showing all the steps but can't promise em all. If any one else has pics to add feel free.
The current pics I'm gonna show are a set of canopy style signs that mount to the wall with 3- 2" square tubing which are pre mounted to wall.  This set of canopies has to fit those specs or it won't be mountable. Here is the first one @10'×42".
  • Like 6
I'll try my best to answer any questions lol.  Here's the next days work. Didn't get pictures at end of day but the 13' and 10' had the mounting supports added, which is where the 2"tube slides in. Main structure was first set of pics posted. The 13' had the rails tackled in which simply support the sheet metal body(you'll see this later). The 10' didn't at this point. But I'll post the finished frame with tacks removed next, so without further a do....
The first steps of this project weren't photographed. But it included bending 1"angle along the faces which also had to be welded together since aluminum sheets used for face (the panel you see front and back) were 8' sheets I cut on cnc. The grind marks you see on face are where that face was joined. Next time i build one I'll try to include those pics.
The face is a high strength vinyl polyester material that is digitally printed.  We stretch the face on with clips that fit in the extrudions. That face was shipped in. We also get faces that are plastic and vacuumed formed but those aren't pictured. Here's a pic of those faces. We do digital prints but not the kind need for large build.
Cool stuff, its always fun knowing tons of people will see your work. Here is a sign we made a few months ago. We also made another set of letters that replaced Special with Football.  Here it is in a video.  (I'm not sure why the pic at the start of the video has the CBS logo, then in the video it uses ours with the NBC logo)
  • Like 5
9 minutes ago, Theultimatehic said:
Making things is always better when thousands see your work! Especially when you get to say,  "Ya i built that".
isn't that the truth brother...
I know the feeling being a retired fabrication engineer, I have or been part of building quite a few things however most of the things were hugely industrial so not many people see it on a regular basis
Alright guys, back to the current build we go.  These pics show the frame all complete and being prepped by an apprentice. This is the last stepin the frame of the build. Now the sheet metal will get laid out and holes cut for lighting. As well as some letters that mount above.
Here you can see them skinned and ready for paint. I'll also show the letters being made. The step that wasn't pictured which i had mentioned will get clarified here.  It's done a lil different but basically the same. Also included a work order pic so you can see what I'm doing.  Enjoy.
    TNBT
    TNBT
