Dan110
1.5m fall, died, xph07z
Hi,
New here.
My makita xph07z fall from 1.5m only.
Straight on the battery.
Battery is broken but works on other tools.
But, the drill is died.
I checked the switch and seems ok.
The red battery indicator light is working.
The drill not turn on.
I'm trying to upload the movie.
There is anything to do?
Thanks, dan.
Share this post
Link to post
Unlucky fall :( sometimes you can get lucky and drop em 10 times off a roof. Other time u get 1 unlucky hit and something's broke :/
Share this post
Link to post
If it's lighting up and making an attempt to run then I'd check the drive train. Make sure any barings in the housing haven't dislodges which might hinder the rotation of the armature or rotor. Make sure the stator is correctly seated. Remove the gearing after the motor and try and run it. If it runs then the issue is in the gear train.
Share this post
Link to post
And if there isn't any clear fall damage ( like broken housing ) try for warranty ? Don't know where you live but in most countries u have a 3 year warranty if you registered.
Share this post
Link to post
Register a new account
Sign in
    Jack_lee
    Jack_lee
