novice121 Posted July 10, 2017 Report Share Posted July 10, 2017 OK, so I was about to buy a Dremel 4300 with all the accessories line ups, and adapters, all Dremel branded stuff out of the Home Depot, but when I held that tiny 6" ish tool on my hand (demo unit), I really felt like an a-hole. It felt weak, and flaccid. I wish to buy a Makita cordless die grinder with a little more balls, and find a way to use some sort of adapter to use it with the tiny Dremel accesories, and also find a way to regulate the speed of the die grinder itself. Is this even possible? The Dremel doesn't look like it's gonna last, and I plan to re-mod my old Makita radio, and add more USB ports, tweeters, amps, and a higher range Bluetooth adapter using a die grinder to take care of all the molding around the plastic housing to mod it. Also, excuse my mannerism, as English is not my first language, and I still need to get used to all of these nomenclatures (Bolivian-American, please). Quote Link to comment Share on other sites More sharing options...
rrich1 Posted July 10, 2017 Report Share Posted July 10, 2017 The Dremel is a fine tool. Which model were you looking at. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
kornomaniac Posted July 12, 2017 Report Share Posted July 12, 2017 For the small holes you will be grinding a die grinder is waaaay too big and clumsy. The Dremel is what you need really :/ Quote Link to comment Share on other sites More sharing options...
novice121 Posted August 6, 2017 Author Report Share Posted August 6, 2017 Sorry for the late reply. You guys are right, I ended up waiting for a Dremel promo, and got it cheaper (model 4300) from eBay with a coupon. I think it'll be a long time until a die grinder can replace a Dremel; not because of the non variable speed, or adapters, but because I'm sure there are patents, and licenses involved. Quote Link to comment Share on other sites More sharing options...
