Cordless Tool Trivia
dwain
Sure. I don't know the answer to this question, but I'll look it up.
Which platform (brand and voltage) has the largest selection of saws, and how many? By this i mean circs, jigs, recip, band, chain etc ...
Please note that I am asking about unique saws. So a different handled/form saw is OK, but multiples of the same sort of saw in brushed, 2nd gen and BL etc don't count.
Example: The M18 line would have two recip saws only (hackzall type and sawzall type).
Example 2: Bosch's 18V barrel-grip jigsaw and d-handle grip jigsaw count as 2.
Example 3: Different size blades count as multiples.
Makita 18V. I'm not sure I can name all of them but here goes:
- Full sized recip
- One hand recip (brushed) with dual trigger
- Subcompact recip
- Circular saw 6.5inch
- Rear handle circular saw
- Metal cutting saw
- Band saw???do they have one
- Barrell grip jigsaw
- D handle jigsaw
EDIT: Total of 9 saws in 18V
Edited by D W
Added total
DeWalt has at least the
Flexvolt platform:
12" sliding miter
12" non sliding miter
Table saw
Track saw
Chain saw
Rear handle circ
7 1/4" sidewinder circ
Recip saw
So that's only 8 if you count that as a separate platform.
20v Max:
Chainsaw
7 1/4" circular saw
Compact recip
Full size recip
6 1/2" circular saw
Metal 5 1/2" circular saw
Deep cut portaband
Standard portaband
Jig saw
7 1/4" miter saw
11 if you count that separate
Milwaukee M18 has 10 by my count, the two bandsaws have different cut capacities so they both count. 3 circ sizes (5-3/8, 6-1/2, 7-1/4), 2 miters (7-1/4, 10), hackzall, Sawzall, and jigsaw.
I thought they had more but was thinking of the corded metal cutting circ which I think is 6-1/2.
2 hours ago, D W said:
- Full sized recip
- Subcompact recip
- Metal cutting saw
- Band saw
- D handle jigsaw
Cut out saw ( Gyproc )DSD180
Multitool DTM ( does it count as a saw ? )
Sliding Mitre saw DLS110
Chop saw DLS600
One Handed chainsaw
Full size chainsaw
CXT glass/tilesaw
Plunge saw DSP
That's 17 if the Multitool counts
Chop saw DLS600
One Handed chainsaw
Full size chainsaw
CXT glass/tilesaw
Plunge saw DSP
I don't count the multi-tool (or the drywall cutter personally, but meh whatever).
I believe the tilesaw only comes in 12V. So by might count you're up to 14.
My answer was Makita with 17 (add their 18x2 7-1/4" circ saw,  their 2nd bandsaw and their 2nd metal cutting saw).
You're up Korno.
  • Thanks 1
7 minutes ago, Jronman said:
wow wasn't expecting to get it right.
What brands offer a drill with easily removable chucks?
 One brand in particular comes with multiple chucks in the kit to easily swap out depending on the task at hand.
As far as I know, it's Bosch (12V and 18V), Milwaukee M12, Festool, Metabo and Fein.
Bosch, Milwaukee and Festool have a few different types of chucks (right-angle, offset, 1/4" bit holder etc)
Metabo have a quick change chuck, but the only compatible 'chucks' are the little 1/4" 'bit holder it comes with, and the huge torque multiplier, so I assume you don't mean that.
FEIN also have a removable chuck with a little 1/4" hex bit holder. Come to think of it, maybe they have other chucks, but I don't remember seeing any.
Metabo also has several angle adapters.
Aeg has 12V and 18V drills with quick change chucks including right angle and offset (in Europe at least).
