10.8V now 12V worldwide
D W
I follow the logic , but in practical terms , two batteries from two different companies both having 162wh of energy ..Do not produce the same amount of cuts, Do not rip the same linear ft of stock....the whole engineer degree thing is great, excellent accomplishment..i am proud of you, I don't have one,but I correct the engineers that set plans for the houses I frame, school of hard knocks, masters degree.....that's all I know battery A  162wh ...battery B 172wh ...Do Not Cut Or Rip the same amount of lumber, not even close
On 8/22/2017 at 6:43 PM, dwain said:
Everything else is marketing bullshit.
On 8/22/2017 at 6:54 PM, HiltiWpg said:
It's idiotic that they can get get away with blatant misleading advertising.
could say the same for 2x lumber right? Force it to be called 1-1/2"x
Did I hear that m12 was actually 12v and not 12v max or could I be mistaken?
The tools themselves have different motors and different efficiency. so you will always get a different results. If you had two identical tools, that were wired for different brand batteries, THEN you might get the same amount of runtime.
If companies REALLY wanted to inform consumers about their batteries, not only would they tell us the accurate Wh of the battery but also the rated output current of the cells. BUT that's unfortunately not the world we live in ... :lol:
I think it would be better if the lumber were more accurately described, but hopefully there the industry is at least consistent in it's inaccuracy ;):P
M12, like all other '12V' lines is actually 10.8V. 3 cells at 3.6V each. Or '12V Max' ;)
Lumber and trim stock,lvl stock, parralam stock,,,all stock is differently measured...there is only a standard for a type of material....one must know what they are buying,.   Again it goes to Not dumbing down the world,but instead educate yourself.. @dwain.not you per say...but people...
.       is the same for welfare, stop giving handouts and force people to work ...there are plenty of jobs always,just people choose not to do them...help yourself,help your neighbor,family,church....but don't tax me to do it,,,,,people are inherently helpful and generous, .......the USA is a gracious,giving,country which helps everyone worldwide..the people will rally together in time of need ,crisis or war....just don't force us, we will do it anyway......
.    as in don't dumb it down,don't standardize,education is the key
The spruce lumber is cut say 2x 4 then kiln dried resulting in 1.5x3.5 but pressure treated stock is 1.625 to 1.75 wide...engineered lumber is 11 7/8" for a 2x12 which measures 11.25 kd.......a 1x 8  measures 3/4x7.25 ....not even close to 1x8....
.     there are no standards, .....again it's all about education, research, not making everything to a standard for the lowest iq to understand......that's my only point..
.   respect your opinion, I always love to learn new things...
Definitely a fan of real world testing. You guys are getting all technical and attempting in depth analysis and blah blah but these tools were meant for working and doing a task. The only true reality is putting them to the actual task they were made for, and the variable will always be the end user. Which is why I'll always take input from people like framer Joe over the garage guys that have controlled environments which is a joke. Tool box buzz puts all this time and energy into setting up their pretty little cut stations for the recip saw comparison and circ saw testing.... It's fun, but useless. Give me your real world application testing. The tests are cute and entertaining, but I take them mostly with a grain of salt.... So many variables out there, enough of the numbers and paper figures, get out and put them to use!
  • Thanks 1
I don't get it. Let's just take a circular saw for example. It has one job and that is to cut something. The tests put on by tool box buzz for example are the same people who actually use them day in and day out. Rob has a company with the same people. In the tests they are replicating that tools one job. So how can they not be accurate? Or show the ballpark range of the tools capabilities? I take their testing over what a manufacturer says any day of the week because they or anyone else actually shows the tool in use. I dont see any difference verses someone taking a camera to a job site and following them for a day.
Tool reviews are really lacking on how the tools perform over the long term (or even more than just a few hours use). Basically they never say anything about it, and I understand it's something that can't really be done.
It's a shame, a tool might come 1st place in performance/features but might be the first one to fail after 12 months. It's declared the winner and we all go out and buy it.
Completly disagree on that point.
It's the variables in real life use that makes any input like for example, framer Joe, completly useless to me. He is very explicit in claiming that the flexvolt has a longer runtime then his crews using the Makita. Yet this week alone 2 people in the Makita talk group on Facebook have purchased  X2 Makita saws to replace their flexvolt  because of lack of runtime.
You know what this means ? Personal testing is flawed and based on too many variables ( and a good dose of fan boying).  Neither framer Joe nor those 2 guys in the Makita talk group have probably done a fair comparison and their views are flawed because of variables introduced on their real life work and experience.
Only a controlled environment ( with a selection of different tests ) gives us a fair comparison in my opinion.
But that's just my opinion ! Too each his own ! :)
Ask a tradie how to best use the tool, and what features are most important.
Ask an independent reviewer how the different brands stack up against each other, and what the latest and greatest is.
Ask God which ones are most likely to last in the long run.
  • Like 4
A controlled environment is the worst at giving me a real world test and feel. That's what the tool is made for after all, real world use!! Like with Rob and the crew, give me input from their actual use on a job site as they were designed and forego the mock trials.  I still think it's entertaining but it never convinces me one way or another which tool to purchase if I were in the market.
That was a great way to put it Dwain, I do love hearing comparisons and features and the latest and greatest. I know you guys like your run time tests (or maybe not!!!) and maybe others do too. The thing I observed was a concentration into using the tool to drill, cut, grind, etc.... Whereas  real world use doesn't give you 100% concentration on that tool, leading to different experiences with whoever is using it. And I love getting that input. Candid, spontaneous, solid info
I don't know what Joe observed between the DeWalt and the Makita saws, nor do we know the exact circumstances of the two on Facebook. And yes, their views are just that based on their uses. Maybe we could get a better picture if we knew lumber type, moisture content, how many cuts were beveled, etc etc we could go on all day. I like the input of The end users of these items and make my decision based on that sometimes, but we don't regularly have input from these heavy users.
Honestly I would love to see Dan and Eric ramp up their involvement into the fields that these tools are made for and get true unbiased input from them. It's cool they bring us the info, but I think they could do something unique by getting out there and allowing the pros to use them more. Like they do with Pat at the body shop etc... (Dwain and Mike, can you do a Oz version perhaps!!???)
Although it's just the tool nuts that care as much as we do anyways lol...
Although, I do have it easy when it comes to cordless tools. Who makes a cordless PVC shears and a PEX expander tool and a copper tubing cutter and a palm nailer and a lot of the tools for my trade? Easy decision there..... :lol:
Couldn't agree more. One good example of this I was thinking about the other week. I had 2 in my workshop, both approximately 2 years old, one of them gearbox blew up and the other just stopped working. I've got a Bosch 5" that's around 4 years old and it hasn't missed a beat. Over the passed 15 years I've used a mix of Bosch and metabo grinders it seems Bosch last longer. One thing I've noticed you get a lot of these box opener tool reviewer that get sent sample metabo grinders, use them for a few hours and say they are the best on the market
Well testing tool durability would be extremely hard and costly to do for reviewers wouldn't it ? It would take hundreds of hours of simulated work to get an idea on durability. There is no way anyone has the time for that.
Every brand/tool also has a lemon now and then. If a reviewer would be testing a tool for durability and it breaks down after 10 hours. Will he declare the tool to be a POS ? To be factual he would have to get a second model, a third model, etc... And use them all for thesame time to check if he had a lemon the first time or the tool has a durability problem.
Would be the best option if reviews could incorporate durability but don't see how that could realistically done :(
It could be done by saying " here is my opinion of This tool now" and follow up a year later and do the same test....problem is most of these reviewers Dont Actually Use Tools it's just a business on you tube...they get free tools,paid for ads , and YT money.........Dewalts 90'day return policy is great,you can actually use a tool all summer and bring it back if it doesn't hold up, get your money back and buy something else....no hassle ,no wear and tear issue...
This is mostly true. I would also be tuning in to actual tradies reviews over others, if they are any good. That's why I like James from OurBuild.
We would like to do the follow up a year later, but the problem is that MOST reviewed tools (not all) don't get a lot more use  after the review. I've probably reviewed 5 impact drivers in the last year, which means that with my own irregular DIY projects, none of them get enough use to speak honestly about long-term use.
A few tools however, do get a lot of use as we just love using them (e.g. Mike and I have both used the M18 FUEL Circ saw extensively), and we will likely talk about this more than once.
I completely agree with the whole “don’t get a lot of use after the review is done” statement. I’ve been sent a few things over the last year to try out and give an honest opinion of, and I do give an honest review. I don’t have 100,000 followers on Instagram so I don’t get anywhere near as much as the big reviewers get and it’s usually not the cool new things I would love to actually test out (I.e. Packout), but I still occasionally get some. Most of the tools I’ve reviewed in the last year are things I’ve actually spent my hard earned money on and decided to post about.
The only thing I’ve recieved that I use somewhat regularly is the 9.0ah battery and rapid charger Milwaukee sent me. The Ax Carbide blade they sent me is in with the rest of my Sawzall blades but I’ve only needed to use it once since the review.
Southwire sent me some stuff to review. I used it, reviewed it, and it’s in my tote if I need it again but I’m not making/running Coax or network cables all day every day.
Klein sent me a pair of wire strippers that I hated even though everyone else on Instagram was raving about them and got on me for not liking them. I gave an honest review and they took me out of their reviewer program. Why would I continue using a tool I hate? There’s no reason for me to update on how they’re doing a year later if I hated them and don’t use them.
Sunex just sent me a set of impact sockets. I don’t need to change tires every day or wall mount TVs. I know they will hold up well because I have a smaller set I paid for last year. That being said I might not have a need to use them again for 6 months to a year (hopefully I don’t have any tire issues), maybe they will get more use when I buy my M12 ratchet maybe they won’t. I got to choose the tool I reviewed based off a small list they put together. There were two service jacks, two sizes of Impact sockets, two sizes of their new chrome sockets, and one or two other things that I can’t remember (or look up on the review site anymore). I chose the item I’m likely to use the most even if it is something I may use once or twice a year.
My most uses tools that I could give an updated review on are tools I paid for with my money. I have them because they’re a tool I actually needed for a project or multiple projects like my M12 5-3/8” circular saw that I’ve had for 2.5 years. DeWalt or Makita could send me their rear handle saw tomorrow and I’d still pick my M12 saw for most of my tasks because 7-1/4” would be overkill for 2x4s and plywood. Same reason I don’t pull out my 7-1/4” or even my 10-1/4” saw everytime I need to cut down a piece of plywood. I’m not going to pick a 17.8lb saw when a 5.35lb saw will do the job better and faster.
    mattyuk
    mattyuk
