kornomaniac
Hitachi multivolt
Found something new online. Hitachi Presented a multi voltage battery in Japan much like the flexvolt.
Can be either a 18v/5amp battery or a 36v/2.5 amps.
A new impact driver and circular to benefit from the multivolt batteries in 36v modus.
Seems they are completly compatible with everything.
http://www.homemaking.jp/product_info.php?products_id=167033&osCsid=1a7f521fc2fbc6e167da0136d206cb05
  • Like 6
Share this post
Link to post
This is pretty cool. Love to see mean green head over this way in strength too.
Share this post
Link to post
all tools get 36v power? or is there 36v specific tools that can work in 18v mode if needed?
Share this post
Link to post
Wish milwaukee would do something similar. They say they are waiting for new cells for their 18v batteries but doesn't that mean that whenever these new cells are abailable that someone like dewalt could also put these news cells in their flexvolt batteries and still keep the advantage?
Share this post
Link to post
DeWalt already has newer cells.20700.
If rumours are true Makita and Milwaukee are waiting on 21700 cells.
Share this post
Link to post
Love that they FINALLY decided to have a friggin' battery gauge on their batteries. Is this going to come to the US, though? Hitachi still has a LOT of higher-end brushless tools that have yet to become available in NA.
Share this post
Link to post
21700 would make flex even bigger than the 9.0 which would seem like a bad idea considering it is already big enough. I think DeWALT should wait for solid state battery tech. If Makita is going 21700 then x2 may start outperforming Flexvolt. They are already pretty close in performance.
Share this post
Link to post
Most Makita tools have a gauge on the tool. Guess you have 2 ways to check battery life now.
Share this post
Link to post
Only by like 5mm at most
Share this post
Link to post
Well in theory 3 mm higher and wider would be enough. Maybe the big flexvolt battery already has that 3mm spare inside the casing if DeWalt thought it trough.
Share this post
Link to post
36v specific tools it seems. The battery can fit either 18v or 36v but you can't fit an older 18v on the 36v tools I think I get out of the japanese
Share this post
Link to post
so closer to flexvolt than x2 I guess
Share this post
Link to post
Linda exactly like flexvolt but then in 'normal' size battery with a Max of 36v.
Anyone have an idea of the flexvolt idea is patented in us/EU ?
Share this post
Link to post
Hitachi's premium brushless tools have a two-bar gauge. Better than nothing but still not as helpful as a 3 or 4.
Share this post
Link to post
All manufacturers should use five bars, four green and one red. It'd cost nothing to implement and give far more accuracy on battery state.
Share this post
Link to post
would a readout of the battery percentage be possible?
Share this post
Link to post
Easily done, but far too expensive. Then there's the issue of durability, most people I know are quite heavy handed with their kit, I can't see screens on batteries lasting long.
Share this post
Link to post
could it just be made out of the same material as the fuel gauges are made of? That soft plastic stuff? Maybe it would have space for 3 digits like what you would see on a digital clock.
Share this post
Link to post
I guess that's possible, but they're always going with the cheaper option. I think you'd need at least one manufacturer to start including that and then hopefully others would follow suit.
Share this post
Link to post
I'm really excited for this as I believe Hitachi's as good an overall power tool manufacturer as anyone when you include their pneumatic tools and miter/table saws into their cordless mix (the Triple Hammer is the best cordless tool out there IMHO). This is like a hybrid of Makita's X2 and DeWalt's FlexVolt and will hopefully result in some fantastic new stuff from Team Green!
Share this post
Link to post
The new tools include:
An impact driver that has 10%+ driving speed and longer run time compared to the the 18v Triple Hammer impact(with 6ah battery)
A 6.5" circular saw with twice the cutting speed of their 18v brushless circular saw.
4" and 5" variable speed grinders with nearly twice the power of their 18v brushless grinders.
A 6.5" sliding mitre saw.
More about the first multivolt tools here:
http://www.hitachi-koki.co.jp/powertools/pro/multivolt/
https://www.youtube.com/user/HitachiKokiChannel/videos
Share this post
Link to post
On 8/26/2017 at 4:21 PM, Tug said:
Surely you can only patent the name and not the tech?
Likely patented the way of disengaging the 60v connection or the way of mechanically switching between voltages. I think they'd issue those patents but you'd likely not be able to patent differential voltage in a battery...but I've heard of more asinine patents getting through. It also is probably limited to the power tool category, so if there is a different industry that could benefit from the tech it should be free game.
Share this post
Link to post
Register a new account
Sign in
    JuliaEDavis
    JuliaEDavis
