greybird7 Posted October 2, 2017 Report Share Posted October 2, 2017 I'm curious to hear if other Makita circular saw owners have experienced multiple failures of the trigger switch. In ten years of ownership, my Makita 5740NB saw has had 4 switch replacements, the latest of which lasted only 4 days, before failing. All switches failed in the "on" condition. Release of the trigger did not shut off the saw. I dismantled two of the switches, and found them to be quite delicate and fragile in construction and design. Are there any company recalls for these switches, or any recourse for customers with out-of-warranty defects? Quote Link to comment Share on other sites More sharing options...
CATERPILLAR Posted October 2, 2017 Report Share Posted October 2, 2017 1 hour ago, greybird7 said: I'm curious to hear if other Makita circular saw owners have experienced multiple failures of the trigger switch. In ten years of ownership, my Makita 5740NB saw has had 4 switch replacements, the latest of which lasted only 4 days, before failing. All switches failed in the "on" condition. Release of the trigger did not shut off the saw. I dismantled two of the switches, and found them to be quite delicate and fragile in construction and design. Are there any company recalls for these switches, or any recourse for customers with out-of-warranty defects? Do u run it on a generator or anything like that . Depends how much u use it if its everyday gets used then switches will wear out but not that fast where do u buy your switches from ? Quote Link to comment Share on other sites More sharing options...
BMack37 Posted October 2, 2017 Report Share Posted October 2, 2017 Switches are always a little delicate looking(it's just plastic and spring steel), I wouldn't put too much weight into that. Are they physically sticking? You can spray some WD40 in there to clean it up but try to blow out as much as you can or it will attract dust. Maybe they have a newer switch that will work in it. Quote Link to comment Share on other sites More sharing options...
Jscott Posted October 2, 2017 Report Share Posted October 2, 2017 My dad had the same problem he changed his three time in a yr or so and then just threw it on the shelf we haven't messed with it since.. mine has been working great for a couple years now but it doesn't get constant use in my shop like his did on our job site Quote Link to comment Share on other sites More sharing options...
