bookum Posted November 14, 2017 Report Share Posted November 14, 2017 Hi... I bought a 9207spc that did not come with the rubber backing pad- they do not seem to be easy to come by or to determine which accessories are compatible but I'm hoping the model(s) that replaced the 9207 would work. In addition, I need to find a resin-backed 36 grit grinding disc (for fiberglass) and a power pad that will work with this tool. I'm also not sure how (or if) the grinding disc works with the rubber backing pad- does it attach (hook and loop?) to the pad or does it attach independently to the tool? Any insight on this would be most appreciated! Quote Link to comment Share on other sites More sharing options...
