tugnut1 Posted February 16, 2018 Report Share Posted February 16, 2018 JET’s new 10 in. ProShop™ Table Saw is loaded with features usually reserved for higher-end saws. Woodworking shop owners and enthusiasts can choose from the standard 30 in. or upgrade to the 52 in. rip fence and select cast iron or stamped steel extension wings. The saw’s interior has an improved blade shroud surround to improve dust collection capabilities. A convenient, oversized magnetic paddle “off” switch is employed for safe operation. The motor’s reset switch has been conveniently relocated to next to the saw’s power switch as well. The JET ProShop saw is powered by a 1-3/4 hp, single-phase motor that’s prewired for 120V or 230V operation. JET’s innovative single-lock ProShop fence design helps provide professional results as it glides easily along the saw’s rails. The left-tilt saw supports sheet goods and other dimensional lumber with the optional 52 in. maximum rip capacity to the right of the blade and 13.5 in. to the left. The ProShop saw also accommodates 8-in. dados with a 13/16 in. width. A dado insert is included with the saw. A miter gauge with adjustable positive stops helps set up cross-cutting operations and miter cuts. The JET 10 in. ProShop Table Saw is covered by a 5-year warranty Specifications Chart Stock #725000K, Model #JPS2-115 Arbor Diameter 5/8" Maximum depth of cut 90 Degrees 3-1/8" Maximum depth of cut 45 Degrees 2-1/8" Maximum rip right of the blade 30" (52" with extension table) Maximum rip left of the blade 13-1/2” Dado maximum diameter 8” Dado maximum width 13/16” Motor Power (HP) 1-3/4 HP Motor phase 1 PH Prewired voltage 120V, 230V Table dimensions with wings 44"L x 27"W Weight 178 lbs. (without wings) 1 Quote Link to comment Share on other sites More sharing options...
