MMiller Posted April 3, 2018 Report Share Posted April 3, 2018 Hey guys, I'm looking for a new angle grinder. Should be used to grind metals and clean weld seams. Really like the Bosch cordless grinders but don't have experience with battery powered angle grinders. See here: https://www.boschtools.com/us/en/boschtools-ocs/cordless-angle-grinders-35699-c/ Does anyone have experience with the Bosch Tools or any other suggestions? Marcus Quote Link to comment Share on other sites More sharing options...
comp56 Posted April 3, 2018 Report Share Posted April 3, 2018 not sure about bosch grinders for cordless I do have a Milwaukee Fuel grinder and coupled with a 9.0ah battery I can't be any happier....here is a shot 3 stages up on scaffolding grinding cement window openings......don't even realize it has a battery.... Quote Link to comment Share on other sites More sharing options...
MMiller Posted April 4, 2018 Author Report Share Posted April 4, 2018 Alright looks not too bad :-) Will check out Milwaukee tools Quote Link to comment Share on other sites More sharing options...
rcarnes911 Posted April 5, 2018 Report Share Posted April 5, 2018 The flexvolt grinder is top dog for cordless grindersSent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
BMack37 Posted April 5, 2018 Report Share Posted April 5, 2018 Honestly any top brand's grinder is going to be good. Metabo is considered the best but you can''t go wrong with any other high end grinder from Makita, Milwaukee, either voltages of Dewalt, Bosch. Since you're in the Bosch lineup, I'd go with that. Though, if you're heavy handed the Flexvolt Dewalt will be the hardest to bog down, followed by the Milwaukee Fuel and Makita X2 grinder. I personally wouldn't buy into Flexvolt because it has limited tools that are developed for that specific platform and it's a big battery to use for 20V stuff, so you'll probably end up buying 20V batteries. I like the Milwaukee line personally, it's a large line with basically any tool you could use. Makita is my second favorite, good build quality, good lineup and the X2 series is soo smart that I'm surprised everyone hasn't ripped it off. Dewalt also loses their advantage of availability since Flexvolt is still limited to certain stores. Also, I wouldn't buy into the Metabo line due to a small line of tools. 1 Quote Link to comment Share on other sites More sharing options...
method Posted December 12, 2018 Report Share Posted December 12, 2018 Im assuming 5"? If you need corded I'd go with metabo, cordless as rcarnes911 suggested the flexvolt is the best I've used. I've had cordless metabo, milwaukee, I've used cordless AEG and hitachi but the new 54v Dewalt truly has cord like power. If you're going to be grinding fillets you should look at some fillet weld grinders too. You will be able to get the wheel just about anywhere and then buy a cheap corded grinder for general grinding. Quote Link to comment Share on other sites More sharing options...
john1053 Posted December 15, 2018 Report Share Posted December 15, 2018 Hello I'm a great fan of the Hitachi cordless tools, and this one is great as well. It's lightweight, but has decent cutting power. I wouldn't use it to build a house, but for light duty home use it's fine. This is perfect for the quick job when you don't want to get out an extension cord and you need to cut a few pieces of rebar or pipe. Or you may need to groove some stone or concrete. Also great for normal grinding applications on metals.I have 3 batteries, so I was able to cycle through them without running out of power. If you have a project that requires a lot of cutting, you would need at least 2 batteries to keep up your workflow. Quote Link to comment Share on other sites More sharing options...
paulengr Posted July 19, 2019 Report Share Posted July 19, 2019 I have the better grade Dewalt corded 11 A version and the Milwaukee fuel cordless. Hands down the little and much lighter Dewalt runs rings around the Milwaukee. If I did it again and I could only buy one, I’d get the corded. But take for instance yesterday where I needed to grind off some rusted bolts and do some sheet metal modifications on a starter I was rebuilding. No idea where the nearest receptacle is and didn’t care. I did everything with the Milwaukee. Now if I had to grind out welds all shift or do a big 1/2” plate bevel or strip paint, it’s the Dewalt all the way. So it depends on what you need to do. If the cord is convenient or it’s a big job, I grab the corded. Otherwise I slap the battery in and go to town. We’ve got some Dewalt 20V Max too. The Milwaukee fuel version does a lot better. It doesn’t stall out nearly as easy. But it’s hard to stall the corded Dewalt.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
okpermanent Posted June 5, 2022 Report Share Posted June 5, 2022 Hello. I burned up two Harbor freight 6amp 4 1/2” angle grinders in the last 20 months. I’ve been cutting some 2” cast iron pipe to remodel 2 bathrooms. I also use it to cut random things here and there but I haven’t been beating on the grinder by any means.airless paint sprayer Los AngelesAt this point I want to move to a better brand. I need to cut a 4” single hub cast iron pipe with a metal cut off wheel.Anyone got recommendations? I see the dewalt DWE402 has 11amps. That’s more than some competing brands. For example the Makita 9557PBX1 only has 7.5amps. What does the 11amps buy me?Also looking for recommendations on cutoff wheels to cut this 4” cast iron pipe.Thanks guys Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted June 6, 2022 Report Share Posted June 6, 2022 I like the new Hilti Grinder. Powerful and just a awesome platform. I like the 3D plan for sensing it offers. Metabo is also know for having some of the best angle grinders. If not, Milwaukee, Dewalt, Makita, Bosch all make great grinders. Quote Link to comment Share on other sites More sharing options...
okpermanent Posted March 28, 2023 Report Share Posted March 28, 2023 On 4/6/2018 at 12:27 AM, BMack37 said: Honestly any top brand's grinder is going to be good. Metabo is considered the best but you can''t go wrong with any other high end grinder from Makita, Milwaukee, either voltages of Dewalt, Bosch. Since you're in the Bosch lineup, I'd go with that. Though, if you're heavy handed the Flexvolt Dewalt will be the hardest to bog down, followed by the Milwaukee Fuel and Makita X2 grinder. I personally wouldn't buy into Flexvolt because it has limited tools that are developed for that specific platform and it's a big battery to use for 20V stuff, so you'll probably end up buying 20V batteries. I like the Milwaukee line personally, it's a large line with basically any tool you could use. Makita is my second favorite, good build quality, good lineup and the X2 series is soo smart that I'm surprised everyone hasn't ripped it off. Dewalt also loses their advantage of availability since Flexvolt is still limited to certain stores Dewalt DWE4517. Also, I wouldn't buy into the Metabo line due to a small line of tools. One of my winter projects is to replace the floors boards in my old Barracuda project car. I believe the tool I need to remove the old floor is a right angle grinder. I do not own one not have I ever used one. I am looking for recommendations on what might do the job. I do not have an air compressor so I am looking at an electrically powered tool. I assume these things will also cut, as well as, grind? Quote Link to comment Share on other sites More sharing options...
