MrNoob Posted June 1, 2018 Report Share Posted June 1, 2018 Hello, I want to use SP6000 track saw to cut aluminium profiles (+ - 2mm thick) also I may need to cut metal insulated panel (0.5mm metal sheet) What saw blade should I use? 1 Quote Link to comment Share on other sites More sharing options...
The.Handyman Posted June 1, 2018 Report Share Posted June 1, 2018 Makita has specific saw blades made for the track saw. There is a non-ferrous blade for metal cutting available. Look through the blade offerings at tool nut or Home Depot website as well as the Makita websiteSent from my SM-G960U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
MrNoob Posted June 2, 2018 Author Report Share Posted June 2, 2018 (edited) Thank you! most of the blades I saw has Carbide Teeth, so can I use any blade with 60+ Carbide teeth? edit: I think I found the blade I need: Makita A-99976 6-1/2" 56T Carbide-Tipped Cordless Plunge Saw Blade and its not cheap 60$ on amazon... Edited June 2, 2018 by MrNoob Quote Link to comment Share on other sites More sharing options...
Tools & Stuff Posted June 3, 2018 Report Share Posted June 3, 2018 In this part of the world the correct blades would be B-56823 (thin kerf) or B-15540 But basically any blade with lots of teeth as you say. I use 60-100 teeth on my mitre saw when cutting Ali. When cutting ACM (0.4mm ali both sides of 3mm plastic) with a circular saw and a 48 tooth wood blade it cuts fine, just don't push too quick. Quote Link to comment Share on other sites More sharing options...
