What a perfect little systainer
The.Handyman
Simple and efficient layout, the ultimate Metabo systainer setup. Every piece is readily accessible and all chucks have a slot.
The insert required minimal modification to fit the Metabo 3 speed interchangeable chuck drill and the new SSD 200 BL impact driver.
There is a lot of space life over for drill bits and other accessories.
This insert should work with most other drill/impact setups as well with slight material removal.
I'll do some test fitting of other brands and post.
The insert is the Festool Ti15 foam insert:
part 703202 - $44b3f238af36db40938b0ea75be5de7c90.jpg3a78383a41a8d09834cf22bf2e024c2e.jpgfb029483d8f64afaacc88d6c39fe6c98.jpgeb31e5d57b87d260c6e67dd1b69a7d89.jpg
Sent from my SM-G960U using Tapatalk
Looks great! Everything fits well.
I've been planning a similar, but not quite as good set-up to do this weekend. I have a Bosch L-boxx but not sure what I'll do for an insert. I have padded bags so I'll probably just put the tools inside of them and throw them in the L-boxx along with driving and drill bits.
