Track/Plunge Saw blade suggestions?
Jronman
FlexVolt track saw uses 20mm arbor blades and can use the Festool 160mm diameter blades. The stock FlexVolt track saw blade is not that good. I recommend going with a Freud 160mm track saw blades.
Makita has a whole 165mm diameter track saw blade range that is fantastic. I am going to see if they fit the DeWalt.
Sent from my SM-G960U using Tapatalk
After I posted the arbor question it took me 10 minutes to find the answer to that one.
What does a quick Google search say 165 mm equals?
You tell us. You have the time to post the question, might as well use that time to just get the answer.
  • Haha 1
I have had very good results with Oshlun blades from Amazon and Tenryu blades. Both have Festool sizes. My ripping blade and aluminum blade are Tenryu and the Oshlun are very good general purpose blades. I have had good luck getting them resharpened as well by a competent sharpening service.
