Sankalp Patil Posted November 12, 2018 Report Share Posted November 12, 2018 Hello, Could anyone let me know what kind of thermocouple is in the heat gun by Makita HG651C? Thanks in advance Sankalp Patil Quote Link to comment Share on other sites More sharing options...
Mycrossover Posted January 4, 2019 Report Share Posted January 4, 2019 Hello, Could anyone let me know what kind of thermocouple is in the heat gun by Makita HG651C? Thanks in advance Sankalp PatilI really doubt it is a thermocouple. They require a mess of electronics to function and would serve no purpose in a heat gun. It is unlikely to be a thermistor, either. What you probably have is a thermal fuse, quite common in heating devices, like heat guns and coffee pots. They are in there in case the device overheats. The temp it pops at should be on the fuse. It is probably in °C. They are generic electronic items available from distributors like Digikey or Mouser but it might be less trouble to get it from Makita, especially if you cannot read the value on the old one. The original may be spot welded but replacements usually come with barrel crimps. Solder would melt. Leave enough of the old leads so you can crimp on the replacement. One size does not fit all. Get the right temp. fuse for your gun.Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
wingless Posted January 4, 2019 Report Share Posted January 4, 2019 Welcome to the forum. It looks like that tool is constructed with one of nine possible specific heating elements to attain the desired temperature output, also dependent upon the input line voltage. Please post an image showing the problematic part. https://www.gepdepo.hu/upload_files/products_documents/robbantott_abra_HG551VK.pdf Quote Link to comment Share on other sites More sharing options...
