HenryQ Posted March 18, 2019 Report Share Posted March 18, 2019 (edited) Hi, I have a Makita HP1621F which is a keyless 1/2” hammer drill. It’s a nice drill, but the chuck has finally failed on me. It will tighten, but after a few minutes use it loosens. First question: does this mean I need to replace just the chuck or might the problem instead/also be with the spindle, compression spring, ball bearing, retaining ring or helical gear, all of which have a bearing on the chuck (see the parts diagram at: https://www.ereplacementparts.com/makita-hp1621f-hammer-drill-parts-c-97_16247_1585.html) I’d hate to throw it away for want of a chuck. Unfortunately, the Makita replacement chuck, even on eBay is pricey ($50 new). I don’t want to spend a lot of money on a new part for an old tool which itself has an uncertain life. It’s only worth getting a replacement chuck for not too much money. So, I’m wondering if any forum readers could suggest an OEM or other chuck that would work in my Makita HP1621F. Note: the description on the drill itself, describes the drill as a 5/8" drill. However, all the descriptions of the drill I've ever seen (on eBay, for example) list it as a 1/2" hammer drill. The Makita replacement chuck is Part Number: 763192-3. My thanks in advance for your suggestions and help. I will very much appreciate them. Edited March 18, 2019 by HenryQ spelling mistake Quote Link to comment Share on other sites More sharing options...
Mycrossover Posted March 27, 2019 Report Share Posted March 27, 2019 Hi, I have a Makita HP1621F which is a keyless 1/2” hammer drill. It’s a nice drill, but the chuck has finally failed on me. It will tighten, but after a few minutes use it loosens. First question: does this mean I need to replace just the chuck or might the problem instead/also be with the spindle, compression spring, ball bearing, retaining ring or helical gear, all of which have a bearing on the chuck (see the parts diagram at: https://www.ereplacementparts.com/makita-hp1621f-hammer-drill-parts-c-97_16247_1585.html) I’d hate to throw it away for want of a chuck. Unfortunately, the Makita replacement chuck, even on eBay is pricey ($50 new). I don’t want to spend a lot of money on a new part for an old tool which itself has an uncertain life. It’s only worth getting a replacement chuck for not too much money. So, I’m wondering if any forum readers could suggest an OEM or other chuck that would work in my Makita HP1621F. Note: the description on the drill itself, describes the drill as a 5/8" drill. However, all the descriptions of the drill I've ever seen (on eBay, for example) list it as a 1/2" hammer drill. The Makita replacement chuck is Part Number: 763192-3. My thanks in advance for your suggestions and help. I will very much appreciate them.From the link picture it looks like a pretty common keyless chuck. I/2" chucks typically have a 1/2-20 thread but there are quite few exceptions. Take the old one off and see what thread it has. A good Brand of replacement chuck is Rohm but they can be expensive. There is new keyless Makita on ebay right now for around $33 with the shipping. If you want to go cheap and it is 1/2-20 thread for with a keyed chuck. You can probably find a decent one for around 10 bucks.Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
