Dewalt angle grinder
Renato
There is an excellent factory document specifying the correct lubricant for Milwaukee tools. This is linked in my forum reply.
http://forum.toolsinaction.com/topic/14322-wingless-milwaukee-0224-1-magnum-38-0-1200rpm-hole-shooter-gear-lubrication/
If DeWALT won't specify the correct lubricant, then find an equivalent Milwaukee tool and use their lubricant.
As far as I know there is no recommended service hours that a grinders grease should be changed at.  I've never done it but with age I'm sure it doesn't hurt to freshen it up.  Recently "Ave" took a hilti grinder apart cleaned it up and regreased it.  He uses a mobil grease and he says it's maybe not exactly what is spec'd but it should be fine.  If it's your first time hearing of "Ave" he's a youtuber that has torn apart hundreds of tools and while he might seem a bit goofy he really is smart and knowledgeable when it comes to tools and mechanical devices.
  • 2 months later...
