ericsmoldt
Dewalt 20V Max String Trimmer DCST920-Change the string?
Hello,
I have a Dewalt 20V Max String Trimmer DCST920 and I think something got jammed in the trimmer head. I have attached some photos of the head, as it is slightly different than the one I see online a lot. I removed all of the string but the spool inside the head casing will not make a full rotation. It stops at about a quarter turn in either direction and will not rotate any further. The head unit will make full rotation without any trouble. With the spool not rotating, I'm not able to load any new line. This trimmer is less than a year old and has not been heavily used. I would appreciate any guidance you could give me.
Thank you,
Eric
Share this post
Link to post
I had the same issue with my 60 volt, I couldn’t figure out how to load it, so I looked it up on YouTube.
They all looked different!
Mine looks just like yours.
I did figure out a way to load it:
Align all the holes. You should see all the way through the head.
Stick a three foot piece of string through the hole and center it .
Rotate the head so the head retracts the string. Leave just a couple inches out.
Start the trimmer and bump the head. If it works as it should, you have wound it correctly.(iDK if you can only wind it one way or if I got lucky, but I did it correctly the first time)
Replace the small piece with a 10’ piece.
Share this post
Link to post
Thank you for your reply! I'm going to give it a try. I'll let you know what happens.
I have that strummer in your last photo do you see the notch in the guard you put a screwdriver in that and slide it in to a hole you line up to lock the head then you undo the head by hand it might be left hand thread like a Moyer saw blade I think but it’s easy to do
Share this post
Link to post
I am currently playing with the same problem on a recently acquired DCST970 (60v). after first use I found that the circularlower part of the spool head (facing upward and not downward) would not move, or just slightly.  Turned out to be large piece of grass or root that got trapped between the lower spool section and the spool mount. Pulled the root/grass loose and the rotation problem disappeared.
Now I need to figure out if I may be misthreading the cutting line through a separate, 1.5" +/- circular center piece underneath the spool head (or bottom) if looking from the top.  There is circular channel that passes through the piece that seem to be a natural fit for the cutting line, but doing so seems to impede the bump feed function.  haven't found an answer to that question yet, but working on it.
Share this post
Link to post
I have owned quite a few weed wackers in my day . The process to change the string has  to be the dumbest design ever invented .
The engineer should not even be allowed to go to his desk to retrieve his things . He should be thrown out the door into the alley beside the building .
other than that the weed wicket works nice ..... just have to set a side a couple hours every month to change string .
Chris
Share this post
Link to post
ok so what is the small piece that you’re replacing with a 10’?
Share this post
Link to post
Just a short 3’ test piece
Share this post
Link to post
A small screwdriver or Allen wrench in that hole will lock the driver in place and allow you to turn the string drum to wind it up
Share this post
Link to post
    Alped
    Alped
