Sign in to follow this
smileblowing
How to choose an electric screwdriver
   Buy_on_Amazon_large.jpg?v=1557272796
   There are three basic options to choose from when buying an electric, or cordless, screwdriver. Which one will make the best choice for the purchaser depends a great deal on what use the tool will be put to. Within each option is also the question of battery voltage as that will play a large part in how much power the screwdriver has and how long the battery will last.
    The basic groups of cordless tools that function as a screwdriver are the cordless screwdriver, the cordless drill driver and the cordless impact driver. Each has its pros and cons and are best at different tasks. The cordless screwdriver is a good choice for very lightweight work, or perhaps driving screws into threaded holes. The cordless drill driver is probably the most useful power tool in the home, and will drive a variety of screws, but is not designed specifically for that task and it is very easy to strip out a  head screw. The impact driver is absolutely the best choice for driving lots of screws or for driving large screws. It is the most powerful, the batteries last longer and it doesn't strip screws out nearly as badly as the other two choices, but it is also a dedicated tool and not much good for anything else.
  In daily life, are you still annoyed about using normal screwdrivers to fix some tiny components? Can this traditional screwdriver come in handy?In general,the answer is no.
    For small household appliances,especially tiny components, we recommend that you learn about the below product.
     Come and have a look at the IFU electric screwdriver.
100010004_236b6229-86f2-40b8-a216-ee0094
   It looks simple,also simple to use.Pen-shaped design is fit for people using habit,which is 18% smaller than whiteboard pen for easy to grip.It comes with twenty different kinds of heads that fit various electronic devices, including drones, digital watch,eyeglasses, laptops and cameras.
   The motor drives screwdriver simple operating and labor saving.White body black button makes the product easy to identify.Easy to master the using method.Simulate the 360° shadow-less lighting design of the medical operating table,embed 3 LED light to brighten the working area.
   With soft button touch feel,cozy press strength,having a surprising operation.Li-ion Battery powered,flexible to change spare battery.
   Users can rotate the screwdriver manually or through its built-in electric motor. The electric motor has a high efficiency mode and a safe mode. It allows a screw to rotate at a rate of 100rpm in a clockwise or counterclockwise direction. When the screw is fully drilled in, the motor stops automatically and users can manually lock the screw.
   The electric screwdriver weighs only 55g and measures Φ15.6x166mm. On a full charge, the model can work continuously for five to six hours. Charging the product only takes 60 minutes.
https://smileblowing.com/blogs/sexual-wellness/pen-shaped-mini-cordless-electric-precision-screwdriver-tools
Share this post
Link to post
I'm not a great expert in such issues, so I always get acquainted with the reviews of experts to know about the advantages and disadvantages of the product I need.
Generally I prefer drills, but I found an article on the comparison of cordless drill and cordless screwdriver, check it out - https://drilling-it.com/cordless-drill-vs-cordless-screwdriver-when-is-a-cordless-driver-the-best-option/
Having read it I realized that the cordless screwdriver suits me more than the drill, because my repair work happens very rarely. Therefore, you need to choose a tool depending on the purpose of its use. How do you plan to use it?
Share this post
Link to post
    Skutni golaz
    Skutni golaz
