N7AS
BOSCH Double-ended bits
Is there any advantage using BOSCH Double-ended screwdriver bits?
I use the double ended impact control bits and yes the advantage with them is you can have different ends on them so for example I use the ones that have a pz2 at one end and ph2 at the other so I just rotate the bit between screws as I use them types of screws daily. I wish the makitagold double ended bits were different at each end as I don’t see the point in it being the same each end apart from when one end breaks or wears out.
Share this post
Link to post
That must be the only double-ended bit that has different ends. I can't even find that one on Amaxon. Are there any other bits like this one?
Share this post
Link to post
No there are others. Lowe's is currently clearing some out. SQ2 and PH2 is a pretty popular one for electricians.
Share this post
Link to post
Which ones are you after meaning what bit do you want at each end ? There’s plenty in the uk on eBay that Bosch do that have different ends 61fcf5835ca36956fa57d3c4b2415db2.jpg50b33061ef66fd30062d71b10a730e9f.jpg84aed253ee5416b116c5c4dc98b522e3.jpg
Share this post
Link to post
I went to the Lowes website and did not see any of those bits listed.
Share this post
Link to post
While I am thinking about it, Where can I get some empty bit clips for the custom case configuration? So, if I do find some double-ended bits, I would like a place to put them. I may have some space in one of my custom bit cases.
Share this post
Link to post
Have to do some leg work and check your store out, manly Lowes clearance deals don’t pop up online until it’s too late
Share this post
Link to post
    CarStereoGuy
    CarStereoGuy
