Makita Router RD1101
spinningreel
After watching some YouTube video reviews of the Cordless Compact Makita Router, I'm starting to lean in that direction.
It has 2 features I like, and LED light & a button to lock the shaft during bit changes.    I already have Four 5.0 Amp hour batteries, so a bare tool would be more economical.  And this will be mostly used for Roundovers on interior shelving and garage hobby type work, etc.
The cordless is hard to beat for the type of work you're describing; it's compact, powerful, and versatile with the availability of the plunge and other bases.  Of the 7 routers I have, 3 are the cordless Makitas (one plunge base, one fixed or offset base, and one on a guide rail sled). They may have slightly less power than the 2 1/4 router you first mentioned (I'm not familiar with it), but I doubt that would be an issue given your apparent needs.  I will say though that the button for bit changes is not very useful; I always end up just using two wrenches.  Also, the dust extraction shroud is a must have.
Called my local Makita Dealer today and told him to order the RD1101 (D handle, 2 1/4 HP corded model).  I think the idea of having the trigger built into the d handle will add in both control and safety.
Now I have to purchase a few Router bits (Roundover, Ogee, etc.)  I see that they come in both 1/4" & 1/2" Shank sizes, and this router comes with both size Collets.
I've heard that 1/2" size shanks perform better.  Any truth to this?  Any tips or advice on bits.
    garikb
    garikb
