Jronman
Tough System 2.0
DeWALT unveiled the Tough System 2.0 at STAFDA 2019. We already knew it was rumored to be coming but it was officially shown off. We are getting a ds150 equivalent, ds300 equivalent, and a ds450 equivalent at the launch. A ds400 and an organizer are coming later. Back when I saw prototype images I wasn't sure what was new besides looks but there has been quite a few improvements. The lid latches now have an automatically locking feature. It is as simple as setting a box on a 2.0 lid and it's already locked. The front latches also got an update. They look to be a hybrid of the 1.0 latches and Packout latches. The gen 2 boxes also have a spot for a label like you get with tstak. The 2.0 lids also have the ability to lock onto a new half width organizer. The organizer locks into a bracket on the center of the lid and the side latch. You can fit 2 half width organizers on one full width lid. The new organizers have updated bins inside which you can instal dividers in a bin for more customizable organization of small parts. 6 bins come in one organizer. I don't have any information on what will come with the ds150 equivalent. If it comes with bins I would like to see the updated organizer bins included instead of the old bins. I don't know if it has a lid tray or not. The lift out tray that normally comes with the 300, 400, and 450 have gotten a significant upgrade. They are now available in at least 2 sizes same length and width but different heights. They are stackable and lockable. They appear to have foam available for them as well. Normally they rest at the very bottom but tabs can be pulled out to allow a tray to rest on the upper part of the box like the 1.0 tray did. The 2.0 boxes have backwards compatibility with the 1.0 boxes but I am not sure how much backwards compatibility. I only saw the 2.0 stuff on top of the 1.0 stuff and did not see the 1.0 on top the 2.0. I also don't know if the new trays are compatible with the 1.0 boxes. I did not see 2.0 version of the drawer unit, cooler, full width organizer, and tote. I did not see an updated wall rack, van rack, or dolley but they are all compatible with 2.0
Share this post
Link to post
These look interesting.  One problem I've had with mine is that the latches work loose when the boxes are jostled too much.  I used to live in a converted cotton mill where it was either drag my tools up and down about twenty stairs, or go twenty times the distance to deal with four steps.  I learned real quick that it was simpler to unstack the boxes and make multiple trips.  Hopefully the resigned latches are a bit more positive.
Share this post
Link to post
@fm2176 I found the gen 1 latches were inconsistent depending on which box you used. Some latches were way too easy to latch and others were a bear to try and latch. The original latch on the gen 1 were easier to latch than the updated version with the metal pin but they didn't hold as well. I think it is hard to tell the holding force on the gen 2 latches. The new latches have the spring loaded feature which may make for a weaker latch but the latches seem beefier which may make the latch stronger so it might be a wash.
Share this post
Link to post
The boxes stay stacked most of the time as long as the feet engage. Only time guy need the side latches is for transport so they don’t fiy. In practice in the back of a pickup as long as they’re loaded with tools they don’t move anyways. Only tube I had one get loose was 45 mph gusts at 70 mph with an empty tote not latched down,
Share this post
Link to post
The ds150 equivalent 2.0 box no longer has the lid tray. The lids in all the boxes have been thinned down. The box does has some new bins which are different than the ones in the half size organizer. There is one bin on each side instead of two and they now have a clear lid. The new tray system only comes in 2 sizes and sold separate from the boxes. Two of the small trays will equal the height of one large tray. The trays will also be available with or without a clear lid. It sounds like the new tray system won’t be a launch item.
Share this post
Link to post
I picked up the 2.0 Radio TS.
Wondering if anyone has modded the clips to secure to the racking. I seen a thread of this done on the Original TS radio. Anybody tried it with the 2.0 Radio?
Share this post
Link to post
    ZacharyDrumm
    ZacharyDrumm
