Swapping blades
BJAYB43
Have you checked the manual?
Quote
Inserting the Saw Blade (see figure A1)
Clean the shank of the saw blade before inserting it. An unclean shank cannot be fastened securely.
Push the saw blade holder 13 upward in the direction of the arrow. Insert the saw blade 8 (teeth in cutting direction) to the stop into the saw blade holder. While inserting the saw blade, pay attention that the back of the saw blade is positioned in the groove of the guide roller 7.
Precise cuts are only possible when the guide roller 7 faces closely but not too tight against the back of the saw blade (the saw blade 8 may not be bent by the guide roller). If required, loosen screw 17 and move the holder 16 of the guide roller in such a manner that the guide roller faces closely against the back of the saw blade. Tighten screw 17 again. f Check the tight seating of the saw blade.
I attached the relevant pics.
    Ballen1114
    Ballen1114
