mikejs Posted June 1, 2020 Report Share Posted June 1, 2020 Im trying to get my neighbors ryobi bp42 leafblower running.He got it from someone for free,it didnt run.The air filter new,new spark plug,and fresh fuel added.The coil was also replaced since it was cheap money.You can crank it until your arm is tired and nothing happens.Did a compression test got 75 psi,cant find an actual spec.Did notice that the top of the piston and cylinder walls were very clean.Im thinking its a motor problem but i need other ideas. Quote Link to comment Share on other sites More sharing options...
DR99 Posted June 5, 2020 Report Share Posted June 5, 2020 The Carburetor is most likely gummed up from sitting its a side effect of ethanol in gas. Quote Link to comment Share on other sites More sharing options...
mikejs Posted June 7, 2020 Author Report Share Posted June 7, 2020 On 6/5/2020 at 2:27 PM, DR99 said: The Carburetor is most likely gummed up from sitting its a side effect of ethanol in gas. sprayed fuel mix thru the carburetor and into the spark plug hole nothing happens did find ryobi forum site that said there were problems with the rings seizing causing a no start ever hear of this problem Quote Link to comment Share on other sites More sharing options...
