Matthew C Posted June 4, 2020 Report Share Posted June 4, 2020 Hey everyone, I was happy to find this forum. I have a bit of a strange question. I have a metal tube with threads on both sides (male and female). See attached picture. I need to attach this to a drill bit. The female threads will be facing out and the male threads will be closest to the drill bit. Any suggestions about how I should go about this? Thanks, Matthew Quote Link to comment Share on other sites More sharing options...
paulengr Posted June 4, 2020 Report Share Posted June 4, 2020 Get a flat disc style sandpaper attachment. Then attach to that. If it’s plastic epoxy will work. If it’s metal need something more substantial. Also depending on what you are doing go with an impact or drill/driver instead and epoxy your thing to an appropriate diameter socket. 1 Quote Link to comment Share on other sites More sharing options...
Matthew C Posted June 5, 2020 Author Report Share Posted June 5, 2020 Those are two viable leads. Thanks for the idea. It is indeed metal. Quote Link to comment Share on other sites More sharing options...
paulengr Posted June 5, 2020 Report Share Posted June 5, 2020 Then you can also braze or weld to attach.Or with two similar sizes (say attaching to socket) you could use.a wide shaft collar and set screws. Quote Link to comment Share on other sites More sharing options...
power to0ls Posted July 15, 2020 Report Share Posted July 15, 2020 you can search google. Quote Link to comment Share on other sites More sharing options...
