newusername84 Posted June 20, 2020 Report Share Posted June 20, 2020 4x4s still require a flip and two cuts with either size saw. The 6 1/2" can cut 2x lumber no problem. The depth of plywood and OSB is no problem with 6 1/2". I'm trying to think on what particular limitations I may run into if I pick up a 6 1/2" cordless saw versus a 7 1/4" cordless saw. Quote Link to comment Share on other sites More sharing options...
boonez40 Posted June 21, 2020 Report Share Posted June 21, 2020 Just the depth and availability of blades. I believe you you can get more options and brands with the 7 1/4 and at a better price. Larger circumference should cut faster in theory. I know I just switched back to a 7 1/4 saw so I will know in a few days how it does compared to my 6 1/2 saw. Now the real question, can I run a 6 1/2 on a 7 1/4 saw. HmmmmmmSent from my SM-N960U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
boonez40 Posted June 21, 2020 Report Share Posted June 21, 2020 I just read the the 6 1/2 saw will not cut deep enough to make 45° cuts on 2x4'sSent from my SM-N960U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Hammer7896 Posted June 21, 2020 Report Share Posted June 21, 2020 I just read the the 6 1/2 saw will not cut deep enough to make 45° cuts on 2x4's Sent from my SM-N960U using Tapatalk The Xsh03 will cut through 1 1/2” on a 45 bevel Mike 1 Quote Link to comment Share on other sites More sharing options...
boonez40 Posted June 22, 2020 Report Share Posted June 22, 2020 The Xsh03 will cut through 1 1/2” on a 45 bevel MikeOk good to knowSent from my SM-N960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
