Moze Posted July 12, 2020 Report Share Posted July 12, 2020 Not sure what caused this, maybe the terminal plug came loose or something. Anyway, I was mowing and the batteries died. Changed batteries and it wouldn't start. Tried to remove the safety key and it wouldn't come out. Disassembled the plastic shroud on the handle and turns out one of the terminals was melted. The nice thing is, you can easily bypass the safety key. You can see in the photos where I removed the melted wire and simply plugged the good wire from the switch directly into the terminal of the green wire. Easy fix. Curious if anyone else has dealt with this.... 1 Quote Link to comment Share on other sites More sharing options...
Big Adam Posted July 13, 2020 Report Share Posted July 13, 2020 Interesting, partly because my key is yellow! Did you routinely plug/unplug the key prior to this, meaning wear could be an issue? I’ve left mine plugged in since Day 1. Quote Link to comment Share on other sites More sharing options...
Moze Posted July 13, 2020 Author Report Share Posted July 13, 2020 I've never removed it. Quote Link to comment Share on other sites More sharing options...
WendyTimmons Posted June 27, 2021 Report Share Posted June 27, 2021 Right in the middle of this now. Disassembled the housing, see the melted part, but don't understand what needs to happen next. Can someone clarify for me? Quote Link to comment Share on other sites More sharing options...
Moze Posted June 30, 2021 Author Report Share Posted June 30, 2021 On 6/27/2021 at 2:59 PM, WendyTimmons said: Right in the middle of this now. Disassembled the housing, see the melted part, but don't understand what needs to happen next. Can someone clarify for me? Did you get this figured out? Quote Link to comment Share on other sites More sharing options...
WendyTimmons Posted July 2, 2021 Report Share Posted July 2, 2021 Nope. 😐 Quote Link to comment Share on other sites More sharing options...
Moze Posted July 4, 2021 Author Report Share Posted July 4, 2021 On 7/2/2021 at 12:16 PM, WendyTimmons said: Nope. 😐 Quote Link to comment Share on other sites More sharing options...
Moze Posted July 7, 2021 Author Report Share Posted July 7, 2021 @WendyTimmons 👆👆👆 Quote Link to comment Share on other sites More sharing options...
Randy Martian Posted Sunday at 02:24 PM Report Share Posted Sunday at 02:24 PM The electrics in mine have burnt out on the joins and key 3 times now, bad design! Probably not the mower for heavy work this helped, thanks 🙏 Quote Link to comment Share on other sites More sharing options...
