Faldoe Posted June 10, 2015 Report Share Posted June 10, 2015 I just got the M18 1/2'' driver set with the 1/4'' impact driver. The model on the 1/2'' driver box says "2606-22CT." I tried it our briefly and noticed there was a considerable about of sparking/arching behavior going on in the drill. A few times a small spark was emitted. Is this normal? I got the set new from International Tool. Thoughts? The Impact driver seems to be more "normal:" minimal internal sparking. Quote Link to comment Share on other sites More sharing options...
DR99 Posted June 10, 2015 Report Share Posted June 10, 2015 It's probably from the brushes wearing in. Quote Link to comment Share on other sites More sharing options...
Faldoe Posted June 10, 2015 Author Report Share Posted June 10, 2015 Ahh, is that a common occurrence? Quote Link to comment Share on other sites More sharing options...
DR99 Posted June 10, 2015 Report Share Posted June 10, 2015 Yes it is. You will probably see the occasional spark too once they wear in also Quote Link to comment Share on other sites More sharing options...
Bigmikez Posted June 10, 2015 Report Share Posted June 10, 2015 yup its normal its happen to me b4 and u might even have a burning smell but don't worry it goes away as long as it don't smoke then u gotta problem. Quote Link to comment Share on other sites More sharing options...
ChrisK Posted June 10, 2015 Report Share Posted June 10, 2015 Yup, all of my guns have done that till they wear in. If you hear any grinding or maybe if the machine bursts into flames you'll have a problem though 1 Quote Link to comment Share on other sites More sharing options...
Migueld510 Posted July 3, 2015 Report Share Posted July 3, 2015 Does this occur when you are engaging the trigger, or releasing it? I am also thinking that it could be the electric brake in action, as from what I understand, it creats a lot of friction to immediatley stop the driver from spinning when the trigger is released. Quote Link to comment Share on other sites More sharing options...
comp56 Posted July 3, 2015 Report Share Posted July 3, 2015 pretty common even back in the day when you would put new brushes in some used tools Quote Link to comment Share on other sites More sharing options...
Bremon Posted July 3, 2015 Report Share Posted July 3, 2015 Brushless tools spark as well and are not suitable to use around sources of ignition. The sparks are just more inconspicuous compared to brushed tools. Quote Link to comment Share on other sites More sharing options...
