Matty Alou Posted August 25, 2015 Report Share Posted August 25, 2015 I was thinking about a 1\2" drive bar. My question is, do I need 1\2" sockets or can I use my 3\8 sockets? Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted August 25, 2015 Report Share Posted August 25, 2015 Since the 1/2" drive refers to the connection of the socket to the bar, you need either 1/2" sockets or a 1/2" to 3/8" adapter for the 3/8" sockets. Because of the torque involved with a breaker bar though it's best not to use any adapters or extensions. Quote Link to comment Share on other sites More sharing options...
WeldfabNeil Posted August 25, 2015 Report Share Posted August 25, 2015 In theory you can always use any size socket with the correct size adapters. However I try to stay away from adapters especially going smaller with a breaker bar. If your using the breaker bar for leverage your likely to just snap the 3/8 adapter. Quote Link to comment Share on other sites More sharing options...
Dan2425 Posted September 15, 2015 Report Share Posted September 15, 2015 In theory you can always use any size socket with the correct size adapters.However I try to stay away from adapters especially going smaller with a breaker bar. If your using the breaker bar for leverage your likely to just snap the 3/8 adapter.and to add onto this if you dont want to use adapters you can buy a 3/8 breaker bar and if you don't have enough leverage you can always use a piece of pipe. Quote Link to comment Share on other sites More sharing options...
