Lowe's deals permathread
BMack37
23 minutes ago, pancing said:
so, you need to find another one of those code thingies for lowes :D
I did not, if I need a code I just generate one myself. Change a number from the sixth, seventh, eighth, ninth or tenth digit the cycle through the last numbers until it takes the code.
6 hours ago, JimboS1ice said:
damn i paid 10 each
You didn't buy that long ago, go in and buy them if they still have them then return with the old receipt. I was told that's how to do price match after a week from the girl at CS.
pretty sad thats what you have to do to get a price adjustment
It's the same at Sears. Also HD at 31 to 90 days...though often the CS at HD just does a return then sells it back to you without saying anything.
3 hours ago, KnarlyCarl said:
That's double the warranty on my Bosch of the same size...
The signs point to a good product, good warranty...and when was the last time you saw a AA or AAA powered tool that came with name brand batteries? Hopefully these will be in @Eric - TIA and Dan's hands soon so we can get an idea on how they function.
I like the display.
I like the display.
Stuart did a post about these last year
http://toolguyd.com/kobalt-laser-distance-measurer/
Skil 30-piece router bit set. Check all your local stores by changing the location online, normal cost is $100. I had one locally selling for $77 and one for $37!!
https://www.lowes.com/pd/Skil-30-Piece-Router-Bit-Set/1059237
Add something to get your subtotal to $50 then use google and slickdeals to generate your $15 off $50 code.
Keep an eye on the Skil sets if they aren't on clearance at your store. The lower stocked stores in Tampa have them on clearance, the higher stock has them at regular price. They're replacing the Skil sets and bits with Irwin branded versions of the exact same sets (and single bits) at the same price.
The total for my 30-piece set came out to $26.47 plus tax.
  • 4 weeks later...
Ok this was what I was thinking, that's  a killer deal dude! But not available anymore
