Lowe's deals permathread
BMack37
I forgot a year or so ago Lowes had a huge pricing error on Dewalt tools people made out like mad before they caught on. Maybe I need to check Lowes more but I kinda gave up as the deals dried up. I still stop in for regular sale items and such but not much clearance hunting. The deals at lowes seem to be appliance/special order returns or one off building supplies. You can make out like crazy on special order returns at Lowes.
If anyone is looking for a nice Bosch 18v combo you can get the powerbox radio free. Basically a free $179 radio. If I didn't already have the same drill and impact I would jump on it!02db5e686da23dcf0dfcad63d5abc6ee.jpg
I don't believe they're supposed to be removable. I think the design just allows them to rearrange the sets so they can use the case for slightly different sets at retailers. I think it's just a happy accident that they don't glue them in, so you should be able to get them out but I don't believe that is the intent, so the larger ones may very well be glued in.
The Dewalt 58-piece set just dropped to $6.48: http://www.lowes.com/pd/DEWALT-58-Piece-Screwdriver-Bit-Set/999957913
This Dewalt Flextorq 23-piece set is $9.98(half price), I don't recommend buying Flextorq but: https://www.lowes.com/pd/DEWALT-23-Piece-Screwdriver-Bit-Set/999956512
Bosch 3.5" ribbed for her pleasure phillips bit, reportedly $1.15 at some stores. Nice bit IMO: https://www.lowes.com/pd/Bosch-3-5-in-Screwdriver-Bit/1051141
Bosch 5-pack of 2" Robertson's for $2.39: https://www.lowes.com/pd/Bosch-5-Pack-2-in-Square-Robertson-Screwdriver-Bits/1051183
Bosch 32-piece impact set for $7.98(I'll be buying this one): https://www.lowes.com/pd/Bosch-32-Piece-Screwdriver-Bit-Set/50235673
Bosch 47-piece driving set for $9.97: https://www.lowes.com/pd/Bosch-47-Piece-Screwdriver-Bit-Set/999912553
I just came back with the Dewalt 58-piece set, the Bosch 32-piece set and a 6" Bosch ribbed phillips($1.48). There were other Bosch deals, just head there and check yourself, it will vary per store. The black oxide Bosch set was one of the other items on sale.
On 6/21/2016 at 8:11 AM, jeffmcmillan said:
Are the bitholder sections in those boxes held in by dovetails supposed to be removable so you can rearrange them?
I can't seem to get them out in some of mine and I don't know if they're glued in or just super tight.
They take a little work to remove and reinstall them. I have removed some and moved them. You can probably slide a screwdriver under one side and turn it to pop it up a little, then slide it to the other side and do the same. I think it is a good feature that they are tight so they don't fall out when you open the case.
