B4N231012 Posted January 31, 2016 Report Share Posted January 31, 2016 Recently I purchased a drill powered Tablesaw (Hitachi branded). But it seems very specific to what model drill I can actually use to power it. I've tried several old drills I have and have had no luck (either the collar was too small and the drill wouldn't stay put or the bit that attaches after taking off the chuck wouldn't fit because the shank was too small or the thread not fine enough). I was hoping someone out there could tell me what drill I need to get this thing up and running or had any ideas on what else I could do to get it running? Thanks to all in advance! Quote Link to comment Share on other sites More sharing options...
jswoger1986 Posted January 31, 2016 Report Share Posted January 31, 2016 You say recently. Can you return itSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 You say recently. Can you return itSent from my iPhone using TapatalkNo I cannot as I purchased it from an auction site Quote Link to comment Share on other sites More sharing options...
jswoger1986 Posted January 31, 2016 Report Share Posted January 31, 2016 I'm sry man I wish I could help. The only advice I can give is to try to re-sell it. I'm sure someone else in this awesome forum will have better advice Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 I'm sry man I wish I could help. The only advice I can give is to try to re-sell it. I'm sure someone else in this awesome forum will have better advice Sent from my iPhone using TapatalkNo problem man, I will probably end up doing that if I can't figure this thing out. Thanks anyway dude. Quote Link to comment Share on other sites More sharing options...
Millerzconstruction Posted January 31, 2016 Report Share Posted January 31, 2016 What's the spindle look like that the drill chucks on? Millerz Quote Link to comment Share on other sites More sharing options...
Millerzconstruction Posted January 31, 2016 Report Share Posted January 31, 2016 And there maybe a piece missing? Is there anything you have found online about it? With the serial number or something? I haven't used one of these so Idk man... Maybe try eBay to sell it if you don't have any luck with it. There maybe a tool nut out there that needs it?Millerz Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 What's the spindle look like that the drill chucks on? MillerzThe bit is supposed to thread onto the we're the chuck removes, but my chick threads into my drill if that makes sense? I'm very new to this so I probably misunderstood your question.That's where is attaches to the drill and the other side has three pins which drive the saw 1 Quote Link to comment Share on other sites More sharing options...
Millerzconstruction Posted January 31, 2016 Report Share Posted January 31, 2016 The bit is supposed to thread onto the we're the chuck removes, but my chick threads into my drill if that makes sense? I'm very new to this so I probably misunderstood your question.image.jpgThat's where is attaches to the drill and the other side has three pins which drive the sawMaybe a older Hitachi would work on it? This is a shot in the dark but the part you have in your hand, will it thread on a grinder? And use the grinder to power it? Or weld a threaded rod onto something that will go in the drill chuck. Like a bit. I'm just Brainstorming. Throwing ideas at you. Millerz 1 Quote Link to comment Share on other sites More sharing options...
Millerzconstruction Posted January 31, 2016 Report Share Posted January 31, 2016 I may be miss understanding you and way off what you're looking for. Sorry buddy. Millerz Quote Link to comment Share on other sites More sharing options...
Stercorarius Posted January 31, 2016 Report Share Posted January 31, 2016 So what I understand is that you have a female threaded piece on both the saw and the drill but you need a male threaded piece on the drill, correct? You could build an adaptor but I would check what Millerz said and try the grinder first. 3 Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted January 31, 2016 Report Share Posted January 31, 2016 I would worry about the gearing between the input and blade if any. If you hook up a grinder it probably will spin the blade way over the rated speed and not have any decent torque. The easiest option would probably be to find a bolt that fits in the saw end and tighten the drill chuck around that. If the bolt is too big for the drill chuck you could grind it down to fit or put a socket over the head with a socket adapter in the drill. Quote Link to comment Share on other sites More sharing options...
comp56 Posted January 31, 2016 Report Share Posted January 31, 2016 I have a couple of questions, why did you buy this? price, uniqueness, was it cheap? did you plan on using it as a regular table saw? Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted January 31, 2016 Report Share Posted January 31, 2016 I would be very cautious about using this, rpms of a lot of drills are lower but high torque, grinders you'd need something variable speed because most grinders spin closer to 10000 so when you would go to run something through all that blades going to do it seize up and kick.JimboSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Logan Posted January 31, 2016 Report Share Posted January 31, 2016 That is a unique table saw Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted January 31, 2016 Report Share Posted January 31, 2016 Not much of a fence for it either what do you plan on using this for?JimboSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JerryNY Posted January 31, 2016 Report Share Posted January 31, 2016 Looking around the web for that model number shows what looks like a really really old hitachi drill hooked up. http://buyee.jp/item/yahoo/auction/x421605185 Kinda an interesting little box, looks like jig saw, grinder and planer attachments were made for it. Quote Link to comment Share on other sites More sharing options...
JMG Posted January 31, 2016 Report Share Posted January 31, 2016 I believe the first item you need to find is a parts list and/or schematic. If you have a model number, you can generally find an online parts supplier that might have it in their database. From the looks of it though, it will be an Asian regional item and may be a bit difficult to find. Hitachi does have some convoluted power designs out there. I used to own one of their band saws that was powered by one of their three horse power router motors using a step-down gear drive to match the rpm that a normal single phase motor would normally produce. It was one of the noisiest tools I ever owned. Quote Link to comment Share on other sites More sharing options...
BMack37 Posted January 31, 2016 Report Share Posted January 31, 2016 Shouldn't you be able to thread a bolt in there? Then you just need to hook up anything that can turn the bolt. you could use nuts for spacers. I'm really worried that it's still not going to have the RPM or torque to cut anything thick or dense. You might be better off finding a used motor with decent specs and hooking it up instead of a drill or grinder. Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 And there maybe a piece missing? Is there anything you have found online about it? With the serial number or something? I haven't used one of these so Idk man... Maybe try eBay to sell it if you don't have any luck with it. There maybe a tool nut out there that needs it?Millerz Maybe a older Hitachi would work on it? This is a shot in the dark but the part you have in your hand, will it thread on a grinder? And use the grinder to power it? Or weld a threaded rod onto something that will go in the drill chuck. Like a bit. I'm just Brainstorming. Throwing ideas at you. MillerzI can't seem to find a thing online and everything is in Japanese :/ That's what I thought and was hoping someone had an idea has to what model it would be? It's the right size for my black and decker grinder but the thread is too fine one the attachment. I tried something like that but it would stay upright in the box of the saw because with the chuck on the clamp that holds the collar can't reach the collar of the drill. That's exactly what I need at this point really so any ideas you have would be appreciated. Cheers. 1 Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 So what I understand is that you have a female threaded piece on both the saw and the drill but you need a male threaded piece on the drill, correct? You could build an adaptor but I would check what Millerz said and try the grinder first.That is correct, but the bit has to come out of the drill after the chuck is removed if that makes sense? So I would have to take a smaller thread that fits the hole in the drill then step it up to a bigger thread that fits the bit for the saw. Just seems like a lot of trouble :/ Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 I would worry about the gearing between the input and blade if any. If you hook up a grinder it probably will spin the blade way over the rated speed and not have any decent torque. The easiest option would probably be to find a bolt that fits in the saw end and tighten the drill chuck around that. If the bolt is too big for the drill chuck you could grind it down to fit or put a socket over the head with a socket adapter in the drill. That was my original thought and plan until I realised if I do that the drill has no support while in the box, maybe I could build a mount, but then I wouldn't be able to adjust the depth of the saw. It's frustrating xD Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 I have a couple of questions, why did you buy this? price, uniqueness, was it cheap? did you plan on using it as a regular table saw?I bought it because of the price and its uniqueness. I got it for 10 NZD plus it came with blades, metal cutting discs etc and also a jigsaw drill attachment which I'm also having the same issue with. Quote Link to comment Share on other sites More sharing options...
comp56 Posted January 31, 2016 Report Share Posted January 31, 2016 oh ok hope you only want it for that reason because it looks like it is a disaster waiting to happen. Even if you get all the right parts and getting it going I wouldn't use it because it just doesn't look safe... or at least I wouldn't use it to cut anything.....nice piece to have if restored but more for a collection than a working tool.... Quote Link to comment Share on other sites More sharing options...
B4N231012 Posted January 31, 2016 Author Report Share Posted January 31, 2016 I would be very cautious about using this, rpms of a lot of drills are lower but high torque, grinders you'd need something variable speed because most grinders spin closer to 10000 so when you would go to run something through all that blades going to do it seize up and kick.JimboSent from my iPhone using TapatalkExactly, it seems hitachi built their early drills to have a chuck mounted on the same size as a 115mm size grinder bolt but with a finer thread? Whereas all my old drills have the chuck thread into the drill. Quote Link to comment Share on other sites More sharing options...
