Putting Bamboo Flooring above fire place...
taylorv1
Hi Everyone, a customer has asked me to put a shelf made from some excess bamboo flooring she has above her fire place. I was wondering how I should attach it to the wall? Finish Nails? Nail Gun and Glue? Some other type of adhesive? Any suggestion?
The bamboo is only 4" wide with tongue/groove. I will be cutting it down to 3 1/2" wide. It is a 1/2" thick. It would go above her tile which is wrapped around on the wall of her fire place. She has no mantle.
post-50808-0-07486000-1454946917_thumb.j
I'd never use nails on anything that requires withdrawal strength. Nails pull out easy too easily unless you're using giant ring shank framing nails. Glue would also probably not be your best bet as the entire weight on your shelf would be held by the drywall paper.
For a shelf, I'd suggest securing it to the studs with structural screws. You can always countersink them and cover the hole with a plug if you want an invisible mount. If you wanted to get fancier, you could also go with blind shelf supports or Z brackets. Either would give you an invisible mount and good strength.
Z brackets are essentially metal French cleats - just thinner than you could make them with wood. Well, I suppose you could make French cleats out of super thin hardwood, but the metal variety it's easier to put together in the field and requires less equipment.
French cleat would work. If I'm under standing what you are doing correctly? Good luck.
Millerz
Like a French cleat but just a floating shelf. Make a frame with solid wood skinned in the flooring. you can use 1/4" ply and attach the flooring to that if it's easier. Secure that to the wall then slide your shelf over the piece.
Check out this video for inspiration.
https://m.youtube.com/watch?v=ZeyLj0Ppukc
Hi,
      A customer has asked me to make a 6' long shelf above her fire place made out of extra bamboo flooring she has. The Bamboo Flooring is 3 1/2" wide w/o tongue and groove. It is only 1/2" thick She is precise on what she wants, but I don't know what the best way to attach the shelf to the wall is. It will be going above her fire place. She doesn't want z brackets, because it would leave a slight gap. She doesn't seem to want any nail or screw holes on the actual face of the shelf. She was asking me about adhesive, to adhere it to the wall, than nail nails at an angle from the top of the shelf through the thickness. Is that a good way? Please help.
Adhesive bad. How about fattening up the base where it's meets the wall and putting in some metal rods through the wall to support the shelf or some free floating tenons. The problem is the material is only 1/2" thick so it doesn't give you too many options. You might want to explain that the material won't have much strength for support too. Maybe double the bamboo and putting a nice edge on it. That will give a little more meat to attach the rods or tenons into a larger mortise
post-49264-0-10632400-1455900844_thumb.pbefore you do anything make sure wall is flat, other wise you might have a gap anyways or the top surface will be following the wall. I would glue three blocks with a 45 on bottom then take three blocks with 45 on the top sink the blocks in wall flush and hang it like a french cleat... if you know what I mean......
You might be able to use concealed mounting hardware along the lines of these:
https://www.thehardwarehut.com/catalog-product.php?p_ref=259675&gshop&gclid=CPvZ75zehMsCFQoNaQodo48BWg
Or if the shelf is not going to be carrying a lot of weight you could use a t-slot router bit with a plunge router to cut screw slots directly into the material in several places on the back of the piece.
That's a pretty neat idea.
This guy is seriously all about the Ryobi. Is he sponsored? I can't think of any other reason he'd have SOOOO much green, right down to the tape measure and hearing protectors.
There is one other solution for creating a concealed cleat system to hang thin material. You could use a plunge router to hollow out the necessary space on the back side of the material and then use a dovetail bit and straight edge to give an undercut on the top edge of the relief. Using a router table and the same bit (or simply a table saw), you can then create a strip of material with the same edge relief to cut your hanging blocks from. I personally do not recommend a full length cleat on thin material, unless your wall is dead flat with zero deviation. Using short cleats over the studs should suffice to hang a light weight project and give you some wiggle room to make any necessary adjustments. Make sure that the material used for the cleats is slightly thinner than the depth of the beveled relief area on the shelf, and once all adjustments are complete apply a couple of small spots of wood glue to the bevel for a semi-permanent fix.
    Ballen1114
    Ballen1114
