Dryer vent cleaning
4 minutes ago, DR99 said:
Yea it was a gas dryer. I caught it super early before the fire got really crazy
We don't have that many gas dryers here which is good because its crazy to have an open flame next to dryer lint. There's just a sheet metal tube thats open in the front and the flame in the middle. If you open up a gas dryer you would see lint on top the tube singed as well as every were else in the dryer. Its more difficult for an electric dryer to catch fire, there would need to be a spark from the motor or else where to start a fire. A gas dryer should not be used imo, they do preform better than electric and cost less to run but what good is it if it burns the house down.
12 hours ago, nordraw said:
Reading this makes me want to take my dryer apart and clean it out. It's new so I am most likely good for a little while though. I'll check it out in a couple of months.
Yea, it should be done once a year, but it depends on your usage if you dry clothes everyday you might won't to do it every 6 months.
  • 4 years later...
To a few, dryer vent flames may feel like a silly dread, however garments dryers represent a huge number of house fires a year. Inability to clean the dryer may put your home in danger of genuine harm to your property and home. On the off chance that your dryer vent hasn't been cleaned in for a spell, you could be in danger.
How would I know whether my dryer vent needs cleaning?
Numerous instances of dryer vent fires happen in light of the fact that individuals don't generally have a clue how to recognize the signs that their dryer vent needs cleaning.
1. You're seeing an expansion in drying time.
On the off chance that your dryer vent is obstructed with build up, sodden air remains longer in the dryer which makes it difficult for your garments to get dry. In case you're finding that your garments simply aren't dry after a standard cycle, you presumably need your dryer vent cleaned.
2. Dryer is beginning to overlook a consuming scent.
On the off chance that you begin to smell a scent from your dryer, it's most probable dryer build up. At the point when build up or flotsam and jetsam amasses in your dryer, there's an expanded danger of fire or other negative impacts.
3. There is a development of dryer build up.
 On the off chance that you see build up around the opening of the dryer, the vent framework should be cleaned.
4. Dryer is hot outwardly.
At the point when the dryer can't deplete air appropriately, the dryer will feel hot to contact toward the finish of a typical cycle.
When would it be advisable for me to get my dryer vents cleaned?
To ensure you, your family, and your home or business, we suggest that you have your dryer vent cleaned by an expert at any rate once every year.
In addition to the fact that it is imperative to wipe out your dryer's build up trap, yet additionally it is essential to have your garments dryer vent cleaned to expel combustible trash, for example, dryer build up, winged creatures home, and pieces of clothing.
The advantages of a dryer vent cleaning incorporate diminished drying time, decreased service charges, increment dryer productivity, and forestalls dryer fires. A standard cleaning can likewise improve indoor air quality notwithstanding dryer effectiveness and vitality investment funds.
In the event that a stopped up dryer vent forestalls appropriate ventilation, carbon monoxide can be delivered into the home. The monoxide hole could put a few regions of your home in danger.
The Dryer Vent Cleaning Procedure:
The dryer conduit administration that we offer is a cleaning of the whole dryer exhaust framework. This incorporates everything from the rear of the dryer, such a distance out to the terminal top outside. Our CDET (Guaranteed Dryer Fumes Expert) will slide the dryer off the beaten path, evacuate the progress pipe, which is the piece that interfaces the dryer to the primary sheet metal channel in the divider. We will hand clean the change conduit piece, and afterward clean the whole length of the lasting sheet metal channel that drives right to the outside.
This cleaning is finished with a mix of our powerful vacuum and our high-compelled air instruments. We will append our powerful vacuum to one finish of this pipe; when the vacuum is turned on, it will put this channel under pull. While the channel is under attractions, we will take care of our particular air apparatuses through the conduit, driving all the build up and different flotsam and jetsam back to the vacuum association. All the garbage will be sucked out and gathered in the vacuum. The air apparatuses will be taken care of all through the whole pipe, paying little mind to its length or number of turns.
When all the build up and different flotsam and jetsam has been expelled, we will go outside to wipe off the terminal top, and bug watch also. We will likewise ensure the terminal top opens and closes appropriately. On the off chance that a client doesn't have a terminal top or nuisance monitor, one can be introduced for them while we are there. When the cleaning is finished, we reconnect the dryer, and set up it back. The last advance is to cycle the dryer to ensure it is depleting appropriately before we leave. For security and proficiency reasons, we suggest having your garments dryer vent cleaned at any rate once per year to forestall fires and broaden the life of your garments dryer.
We likewise offer Bug Monitors that are intended to fit over garments dryer and washroom exhaust vents. This assists with keeping winged animals and rodents from entering your home through the vents.
  • 4 weeks later...
  • 11 months later...
There's no way we would take responsibility for fixing the dryer vent. Why? Because the developer forbade us to change something in the locations. We'll even install an air conditioner only with his permission. Our extractor hood in the kitchen is installed strictly according to the plan of the house. And this is correct. I know how hard it is to plan and think through everything, so I easily accept strict rules. When we repaired the dryer's air vent in the house, we called https://www.ajmechanicalservices.co.uk/ to help with this. They did everything efficiently, our landlord was satisfied.
