wildroamer Posted July 19, 2016 Report Share Posted July 19, 2016 Also, make sure you are only powering on the drill after bit hits wood. Don't allow it to needlessly chew up the walls of the jig. 1 Quote Link to comment Share on other sites More sharing options...
comp56 Posted July 19, 2016 Report Share Posted July 19, 2016 Dipping or lightly coating your kreg bit in bees wax once in awhile will also help with sliding through the jig and cutting the wood..... 1 Quote Link to comment Share on other sites More sharing options...
olletsocmit Posted July 20, 2016 Author Report Share Posted July 20, 2016 Dipping or lightly coating your kreg bit in bees wax once in awhile will also help with sliding through the jig and cutting the wood..... Wow you're right thanks a lot it's a great tip! Quote Link to comment Share on other sites More sharing options...
olletsocmit Posted July 20, 2016 Author Report Share Posted July 20, 2016 I really want the larger kit with the clamp seems like it be much much nicer in the Jager also is solid metal where the drillbit goes. Seems like I could do a lot more with the clamp one instead of the R3. Both would be ideal does anybody have the are three XL it's the one made for 2 x 4's and larger that really looks handy Quote Link to comment Share on other sites More sharing options...
olletsocmit Posted July 20, 2016 Author Report Share Posted July 20, 2016 Clamps... so i need another one that is bigger then the little guy the R3 came with. what do you guys there would be better and more utilized... the reason i am asking is b/c i have a coupon that Lowe's honors that takes 50% off a single item. 6" clamp, this one seem to be the most widly used one, but i could be wrong: This one looks great, but only for after the holes are drilled, right? So would need 2 just to utilize this one? or the 8" bar, seems to be not too small and not to big... Quote Link to comment Share on other sites More sharing options...
comp56 Posted July 20, 2016 Report Share Posted July 20, 2016 I say the first one you posted, reason being as you can angle it to fit most boards because the jig needs to be at edge Quote Link to comment Share on other sites More sharing options...
comp56 Posted July 20, 2016 Report Share Posted July 20, 2016 I also use one of these as well more often than i thought I would... but again that is after the holes are drilled... 1 Quote Link to comment Share on other sites More sharing options...
DaveJr. Posted July 20, 2016 Report Share Posted July 20, 2016 Get the first two you posted.( 6" face clamp and right angle clamp.....both automaxx) Quote Link to comment Share on other sites More sharing options...
olletsocmit Posted July 26, 2016 Author Report Share Posted July 26, 2016 Mail call. Quote Link to comment Share on other sites More sharing options...
olletsocmit Posted July 26, 2016 Author Report Share Posted July 26, 2016 I also use one of these as well more often than i thought I would... but again that is after the holes are drilled... Where can I buy this!! ?? Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted July 26, 2016 Report Share Posted July 26, 2016 Where can I buy this!! ?? Rockler, well known woodworking tool and supply store, they have a website you know Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
comp56 Posted July 26, 2016 Report Share Posted July 26, 2016 1 hour ago, olletsocmit said: Where can I buy this!! ?? http://www.rockler.com/pock-it-hole-clamp-with-quick-release 1 Quote Link to comment Share on other sites More sharing options...
LarryS Posted July 26, 2016 Report Share Posted July 26, 2016 11 hours ago, olletsocmit said: Where can I buy this!! ?? https://www.amazon.com/Rockler-Pock-it-Hole-Clamp-reg/dp/B005INJYQK Quote Link to comment Share on other sites More sharing options...
Logan Posted July 27, 2016 Report Share Posted July 27, 2016 Those are really nice but if you are willing to spend a little more the porter cable pocket hole jig I think is a lot nicer 1 Quote Link to comment Share on other sites More sharing options...
