rrich1 Posted December 26, 2016 Report Share Posted December 26, 2016 Speaking of caulking, I used to hate it then I found a trick along these lines and love how it turns out since doing it this way .. Would you like to share with the whole class? [emoji12] Sent from my XT1254 using Tapatalk Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted December 26, 2016 Report Share Posted December 26, 2016 2 minutes ago, rrich1 said: Would you like to share with the whole class? Sent from my XT1254 using Tapatalk Hmm I put an Instagram link in, maybe you can't see it in Tapatalk? https://www.instagram.com/p/BNfuglLh60I/ Quote Link to comment Share on other sites More sharing options...
rrich1 Posted December 26, 2016 Report Share Posted December 26, 2016 Hmm I put an Instagram link in, maybe you can't see it in Tapatalk?https://www.instagram.com/p/BNfuglLh60I/ I can see that one. When I repainted the house and caulked the seems I used just water. Have to try soapy water next time. I didn't get to caulking today. Kids wanted at time. LolSent from my XT1254 using Tapatalk Quote Link to comment Share on other sites More sharing options...
phffter Posted December 26, 2016 Author Report Share Posted December 26, 2016 this is a tool forum, so, an incomplete listing of tools used to perform the werk. harbor fright beam type 1.5 hp wet 7'' saw. #62757.bought last year to do 2nd floor bath, about $250. tool worked somewhat satisfactory, the legs are cheap shit, 1 got mangled. saw blade is (was) true to beam/fence. water pump was more than adequate, had to attach rubber flaps to minimize over spray. built a visqueen 'cocoon around the saw work place. placed 'strategic' rags on the table to minimize overspray. sump does drain from bottom, a big plus. miter gage was useless, as it is strictly right handed, and the motor (on the right side of the blade) has only about an inch of clearance over the deck. towards the end of the, didnt have time to check what's what, cuts weren't square. blade used was a bosch 7'' continuous rim, bought from cripe. one blade was used for the entire job. maybe thats why things werent square at the end. (i'll figger this out later) previous job, (2) hf 7'' continuous rim and a dep (home depot) blade was used, in a larger bath, with way less cuts. diamond grit hole saws were bought from mc master, no name, 1 1/8 & 4''. worked very well. pilot drills also from mc master. holes drilled in tile, used ryobi glass/tile bits. poor tool, or mis application by me. the no name bit given to me out lasted the mulitple ryobi's i trashed. electrical device square holes were cut with a 4'' continuous rim ridgid dry blade. worked very well, and did not kick up as much dust as i thought. my mud mixer drill was a single speed USA milwaukee right angle drill. other drills used, 3/8 and 1/2 USA milwaukee vsr. 1/2 18v ridgid. 3/8 12v milwaukee. saws, USA milwaukee sawzall, USA porter cable left handed circular and jigsaw, 18V milwaukee sawzall, 12v milwaukee circ and hacksall. 12'' dewalt sliding double bevel. 10'' crapsman table saw. 3x21 USA porter cable belt sander. 18 ga porter cable finish and brad nailers. metabo 4 1/2 and 6'' grinders. a whole ensemble of countless hand tools. i did find that a new dewalt 25' tape, with the huge end, was a royal pia. that one was retired, used mostly 25' fat max and a 3/4 wide 25' craftsman incomplete pics of tools. if more is desired, i might be able to accommodate. 2 Quote Link to comment Share on other sites More sharing options...
stevep2204 Posted December 27, 2016 Report Share Posted December 27, 2016 On 12/24/2016 at 6:20 PM, phffter said: kicked the job hard in the arse. tiling and grout is done. only have to calk and hang the hangers on the wall. and SHE still has to take care of the tile haze. Looks awesome! Great work! Quote Link to comment Share on other sites More sharing options...
