tugnut1 Posted December 12, 2016 Report Share Posted December 12, 2016 Here is the finished product of my overarm dust collection attachment for my Ridgid R4512. Everything below will let you know how and why I did what I did. I finished connecting all of my tools to my new dust collection system recently. Now I am just tweeking some connections to optimize my dust collection abilities. I've wanted an overarm dust collection system after the first time I was it on the SawStop cabinet saw. You might not think so, but with a zero clearance insert plate on my tablesaw, I end up with a good amount of dust coming off the top of the blade....especially if I am cutting thicker stock. Last week, I collected a lot of images off of the internet with what other people have done. In case you were wondering, there isn't a lot of different units out there. I have the Ridgid R4512 tablesaw and this unit has one really useful feature that a lot of different saws don't have that makes add-ons to this unit simple. the back railing that the fence rides on is made from two pieces. In order to connect those pieces, there is a small bar that sits in a tee track and connects the two pieces. Since this bar only takes up about 6 inches (if I remember correctly) there is plenty of space to add an outfeed table and this overarm unit. I just used some toilet flange bolts to connect this unit to the saw through the T track. I had some of the unit welded up by a friend, but I didn't have all of the measurements, so I had to bolt some wooden braces to the unit. This is temporary, so I will fix this soon. I made the dust collection shoe so that it can be lifted up and down from the saw blade. I still need to add some 2" bristles to this unit so I can slide the stuck under it and not affect the dust collection ability. I attached to springs to the back of the arms to assist in the lifting of the shoe. It really makes it nice for lifting and holding the unit in place. I have the ability to move the shoe close to the blade either way to fit what I am cutting by adding some threads to the square tube I added to my smaller square tubing. You may have noticed the bungie cord attached to the top of the horizontal arm. It was added since the long section of the arm has all of the weight and bounces a pretty good amount. I have more permanent fix for this problem that I am going to have taken care of before the end of this week, so I will share pictures then. I still need to add the 2.5" hose to the shoe as well as the saw stache. I just wanted to see if this was possible before I ordered the parts......so follow up pictures to come. 3 Quote Link to comment Share on other sites More sharing options...
Foneguy Posted December 12, 2016 Report Share Posted December 12, 2016 Nicely done !!!!! 1 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted December 12, 2016 Report Share Posted December 12, 2016 Very cool, nice work I like your take on it! Comp just made one for his tooSent from my iPhone using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted December 12, 2016 Author Report Share Posted December 12, 2016 Very cool, nice work I like your take on it! Comp just made one for his tooSent from my iPhone using TapatalkI didn't see it. I'll have to check for his postSent from my SM-G900V using TapatalkI just found the thread......I do remember seeing it. As a matter of fact, it was the reason I started thinking about making it. I completely forgot. Comp does some awesome stuff. 3 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted December 13, 2016 Report Share Posted December 13, 2016 3 hours ago, tugnut1 said: I didn't see it. I'll have to check for his post Sent from my SM-G900V using Tapatalk I just found the thread......I do remember seeing it. As a matter of fact, it was the reason I started thinking about making it. I completely forgot. Comp does some awesome stuff. yeah, that was cool, useful stuff sitting around waiting to have a second life as Comp's dust collection setup! @comp56 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted December 13, 2016 Report Share Posted December 13, 2016 10 hours ago, tugnut1 said: I finished connecting all of my tools to my new dust collection system recently. Now I am just tweeking some connections to optimize my dust collection abilities. I've wanted an overarm dust collection system after the first time I was it on the SawStop cabinet saw. You might not think so, but with a zero clearance insert plate on my tablesaw, I end up with a good amount of dust coming off the top of the blade....especially if I am cutting thicker stock. Last week, I collected a lot of images off of the internet with what other people have done. In case you were wondering, there isn't a lot of different units out there. I have the Ridgid R4512 tablesaw and this unit has one really useful feature that a lot of different saws don't have that makes add-ons to this unit simple. the back railing that the fence rides on is made from two pieces. In order to connect those pieces, there is a small bar that sits in a tee track and connects the two pieces. Since this bar only takes up about 6 inches (if I remember correctly) there is plenty of space to add an outfeed table and this overarm unit. I just used some toilet flange bolts to connect this unit to the saw through the T track. I had some of the unit welded up by a friend, but I didn't have all of the measurements, so I had to bolt some wooden braces to the unit. This is temporary, so I will fix this soon. I made the dust collection shoe so that it can be lifted up and down from the saw blade. I still need to add some 2" bristles to this unit so I can slide the stuck under it and not affect the dust collection ability. I attached to springs to the back of the arms to assist in the lifting of the shoe. It really makes it nice for lifting and holding the unit in place. I have the ability to move the shoe close to the blade either way to fit what I am cutting by adding some threads to the square tube I added to my smaller square tubing. I still need to add the 2.5" hose to the shoe as well as the saw stache. I just wanted to see if this was possible before I ordered the parts......so follow up pictures to come. Do you think the added weight of the hose will be too much for the springs to hold it up? Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted December 13, 2016 Author Report Share Posted December 13, 2016 Do you think the added weight of the hose will be too much for the springs to hold it up? I don't think so. There should only be a couple of feet on it. Plus I have a thumb screw on one of the bolts to lock it into place if I need to.Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
comp56 Posted December 13, 2016 Report Share Posted December 13, 2016 great stuff, I didn't even notice you have the same R4512, ya mine is a bit more stream line in it is very simple and light weight. swings right up out of the way when not in use almost as if it is not even there. it is no question 90% effective when a zero clearance insert is used. I tend to have it in the saw most as I usually cut large stock with band saw then jointer then planer then table saw to reach finished size 1 Quote Link to comment Share on other sites More sharing options...
Jronman Posted December 13, 2016 Report Share Posted December 13, 2016 looks nice 1 Quote Link to comment Share on other sites More sharing options...
RAM Posted December 17, 2016 Report Share Posted December 17, 2016 Very nice looking Sent from my SAMSUNG-SM-G935A using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted December 18, 2016 Author Report Share Posted December 18, 2016 I had some time to tweek and work on my table saw dust collection attachment. I decided to get rid of the wooden braces by adding some welded braces and then minimize the sagging at the end where the shoe attaches by running a cable with a turn buckle around the outside of the frame. I added the saw stache to the outside of the dust shoe. This was pretty much the only real disappointment in my build. I ordered the saw stache forgetting that there are at least two different siffnesses to bristles. I was hoping to get bristles that were like the ones I got from the people at Kent CNC when they made the dust shoe for the X-carve...the second time. The first one they made, the used stiff bristles and the second shoe they made had really soft bristles that flexed when it went over a board. The ones I am using are really stiff and make it difficult to run wood under it easily. Bummer. I also need to cut the extra length of bolts off and run them in the inside. By leaving them outside, I figured I would eliminate any issue with potentially hitting them with the blade. But by doing it this way, I can't get my push stick down the side without catching a bolt........all in the process. I also quickly changed up how the springs were attached. Lastly, I took it all apart, painted it grey to match the grey on the table saw legs and then made up Ridgid emblem on the X-Carve to make it look like it might come with the table saw. This part was inspired by Comp56's zero clearance insert plate details. 3 Quote Link to comment Share on other sites More sharing options...
ChrisK Posted December 18, 2016 Report Share Posted December 18, 2016 Friggin awesome bro!!! 1 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted December 19, 2016 Report Share Posted December 19, 2016 Sweet deal John I love itSent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted December 19, 2016 Author Report Share Posted December 19, 2016 13 hours ago, ChrisK said: Friggin awesome bro!!! 11 hours ago, JimboS1ice said: Sweet deal John I love it Sent from my iPad using Tapatalk Thanks guys. Quote Link to comment Share on other sites More sharing options...
LarryS Posted December 19, 2016 Report Share Posted December 19, 2016 Looks like that should work nice for you. Great job John !!! 1 Quote Link to comment Share on other sites More sharing options...
regopit Posted December 20, 2016 Report Share Posted December 20, 2016 This looks like something you would see on shark tank. Great idea and execution but knowing how I am with safety guards it would be laying in a corner somewhere after a day. 2 Quote Link to comment Share on other sites More sharing options...
MikeyB Posted December 20, 2016 Report Share Posted December 20, 2016 Wow John, now that is impressive. Great work 1 Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted December 20, 2016 Author Report Share Posted December 20, 2016 I'm not entirely happy with the shoe. I believe I'm going to redo the shoe this next week or two. The bristles are way too stiff. I think that I am going to order some 3" bristles from Kent CNC and make the shoe very similar to their dust shoe for the X-Carve. I'll share pictures as I go along. 1 Quote Link to comment Share on other sites More sharing options...
comp56 Posted December 20, 2016 Report Share Posted December 20, 2016 24 minutes ago, tugnut1 said: I'm not entirely happy with the shoe. I believe I'm going to redo the shoe this next week or two. The bristles are way too stiff. I think that I am going to order some 3" bristles from Kent CNC and make the shoe very similar to their dust shoe for the X-Carve. I'll share pictures as I go along. I found the same problem with the first few I tried. but I found some from a very soft brush and they work great 1 Quote Link to comment Share on other sites More sharing options...
Logan Posted December 20, 2016 Report Share Posted December 20, 2016 Looks really nice Quote Link to comment Share on other sites More sharing options...
Nordraw Posted December 20, 2016 Report Share Posted December 20, 2016 Very nice dude. 1 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted December 26, 2016 Report Share Posted December 26, 2016 Love it. Sent from my XT1254 using Tapatalk Quote Link to comment Share on other sites More sharing options...
tugnut1 Posted January 6, 2017 Author Report Share Posted January 6, 2017 I was able to find some 1/2" cast acrylic on amazon and ordered a 18" by 24" sheet so that I could cut a new shoe with my X-Carve. The 1/2" stuff is expensive, but really cool to work with. I also contacted Kent CNC (they make the split shoe for the X-Carve) and bought some 3" long bristles that ended up being much nicer to work with than the FastCap Sawstache. It took an afternoon, but I am much happier with my dust shoe now. 2 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted January 6, 2017 Report Share Posted January 6, 2017 looking good john! 1 Quote Link to comment Share on other sites More sharing options...
Bigmikez Posted January 6, 2017 Report Share Posted January 6, 2017 Man awesome set dude 1 Quote Link to comment Share on other sites More sharing options...
