comp56 Posted February 17, 2017 Report Posted February 17, 2017 picked myself up a better solution for dust control, 2HP 1200 CFM with 1 micron bag. I am going to make this single stage collector into a dual stage with adding a cyclone eventually.. 4
Foneguy Posted February 17, 2017 Report Posted February 17, 2017 I went to HD today looking for this, (and I thought this was an upgrade) i have to order it.....
CATERPILLAR Posted February 17, 2017 Report Posted February 17, 2017 19 minutes ago, comp56 said: picked myself up a better solution for dust control, 2HP 1200 CFM with 1 micron bag. I am going to make this single stage collector into a dual stage with adding a cyclone eventually.. Very nice man is it standard 4 inch
comp56 Posted February 17, 2017 Author Report Posted February 17, 2017 it can be but it starts out as 6" then it has an adapter for 2 - 4" ports I only have 4" hose so ya it will be 4" to table saw and miter saw 2
comp56 Posted February 17, 2017 Author Report Posted February 17, 2017 calculated the angles to make a sheet metal cyclone basic size will be 30" tall 24" at the top and 12" at the bottom. with a 4" out port on top and a 4" intake port on side. I have the sheet metal just have to cut it and weld it up.....suppose to be around 50+ degrees all next week so hopefully will get it done then ( want to do the cutting and grinding and welding outside for obvious reasons) might even go a little smaller and follow the size of this metal one 2
Logan Posted February 18, 2017 Report Posted February 18, 2017 You will definitely be happy after the first use by not having dust everywhere and breathing it in
comp56 Posted February 18, 2017 Author Report Posted February 18, 2017 40 minutes ago, Logan said: You will definitely be happy after the first use by not having dust everywhere and breathing it in well my 6.5hp shop vac and dust deputy wasn't that bad.....lol but I am hoping for an improvement 2
KnarlyCarl Posted February 19, 2017 Report Posted February 19, 2017 Looks like your guaranteed an improvement already.... I really want to get a cyclone for the shop dust collection unit and maybe move it outside in a little enclosure of its own
