Rust Prevention
Jronman
19 minutes ago, JimboS1ice said:
Even a light wipe of regular wd-40 will help keep rust off of most metal surfaces
I tried this and it didn't seem to keep up. I should be more diligent in my efforts....I will try the specialist
yea thats for routine maintainance, the specialist is more coated for that, 3 and 1 oil has a rust prevention oil too you can give a shot
EDIT: You got that shitty ocean air though don't you...
Not so much the salty air, I'm a few miles (5) away, but the humidity is sick
That's what's nice about where i'm at in Ohio, far away from oceans... although whenever it rains heavy, there are quite a few bodies of water that stick around for awhile. It's the Great Black Swamp trying to reclaim its territory..
I like Comp's father's idea, i too, have to deal with an unheated garage BUT last summer i popped in an old window shaker A/C and that really helped control the humidity.
It's the temp swings in the winter that help attract moisture on cast iron and leaves a layer of rust oh boy..
so then i do this:
Now i've been taking preventative measures to not let this happen again...
so then i do this:
temp fluctuations don't help either but at least us in the middle of the country don't have salty ocean air, thats much worse than what we get, devil air for metal
I really don't know why table saw manufacturers especially high end cabinet saws don't get their beds plated with industrial hard chrome, like on hydraulic cylinders not bumpers. (not the shiny nickle plating)  you could put a flash electroplate on it in seconds and it would most likely last 25+ years sliding wood across it. We used to flash plate hog heads and they lasted 10 times longer but seen 1000 time more abuse than any table saw would see in it's life time. the hard chrome would not even be noticed as under 4 or 5 thousands of an inch it is transparent and a flash plate would be probably less than half a thou
then how could they make money off you buying a new table saw in 5 years?
    TNBT
    TNBT
