Hugh Jass Posted November 22, 2017 Report Share Posted November 22, 2017 Just a FYI the trigger lock also holds the stepped triggers into the full speed so you don't have to hold it. 1 Quote Link to comment Share on other sites More sharing options...
Makita_2233 Posted November 22, 2017 Report Share Posted November 22, 2017 4 hours ago, Framer joe said: Ya now I know ...I couldn’t. figure out that trigger...stepped hugh? Seemed weird thought it was my tool and hard to press fully....not liking it.....probably going back.. It’s a rocker style tigger on the die grinder Quote Link to comment Share on other sites More sharing options...
D W Posted November 22, 2017 Report Share Posted November 22, 2017 The trigger is harder to press than the OMT trigger. I've found it has to be absolutely ALL the way down to reach full speed. Even just 0.5mm off and it's one step below full. Great tool though, can't wait to do something with it. Quote Link to comment Share on other sites More sharing options...
Framer joe Posted November 22, 2017 Report Share Posted November 22, 2017 Thanks for the info....don’t like that step trigger Quote Link to comment Share on other sites More sharing options...
D W Posted November 23, 2017 Report Share Posted November 23, 2017 Unless this one is broken or I'm doing something wrong, but I can confirm the die grinder does not have a lock on switch like the OMT. Quote Link to comment Share on other sites More sharing options...
Makita_2233 Posted November 24, 2017 Report Share Posted November 24, 2017 23 hours ago, D W said: Unless this one is broken or I'm doing something wrong, but I can confirm the die grinder does not have a lock on switch like the OMT. You are correct, the die grinder doesn’t have a lock out switch. The rocker switch frees up after a bit of use 2 Quote Link to comment Share on other sites More sharing options...
