Ryobi miter saw stopped working
DougS
After not using the miter saw for some while, I tested it with a partially discharged battery (18v +one).  Worked fine.  I charged the battery (maybe a coincident action only) and the saw now does not work.  Instead of spinning, the blade makes a short ratchet move and stops with each pull of the trigger.  I don't recall whether the saw is a +one or not.  It is 18v.  I've read the lithium One batteries should work on older model Ryobi (it works with my older hand drill).  It worked fine before I charged the battery (again, maybe coincidence).
Appreciate any suggestions about what may be causing the saw to start/stop in short ratchet when I pull trigger?
Thanks!
Doug
  • 2 years later...
    Chiefifd
    Chiefifd
