chris301up Posted August 17, 2020 Report Share Posted August 17, 2020 I own a Bosch ART30 GSD (not combi-trim) corded strimmer which I have had for some time. It works absolutely fine with the exception that recently the spool line keeps coming of the spool during use. Initially I discovered that the 'slider' was broken so replaced this but it didn't help. Since then I have also replaced the spool cassette and head cap but still non of this as rectified the problem. What I cannot understand is that the 'slider' (picture attached) just slots into a recess at the base of the fitting but it doesn't seem to do anything. On closer inspection I think there must be a part missing as I think the 'slider' must be held in position and push against the spool cassette to prevent the line from coming off? Maybe by a spring or something very similar? I may be mistaken, but I thought I'd post on here to see if anyone would know anything about these strimmers? Any advice would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
robertcladner84 Posted September 23, 2020 Report Share Posted September 23, 2020 Those blue trimmers are REALLY EXPENSIVE$$$$ at $30AUD for a pack of ten. I trim grass at my house and every 10-20M I go through 5 of them! Absolutely useless and disappointing 😠🛠🔧 Quote Link to comment Share on other sites More sharing options...
