Juraj Posted December 13, 2020 Report Share Posted December 13, 2020 Hello, I have problem with DCN660 nailer, When i press trigger left light flashes 20 times. Motor doesn't run. When i opened it and reinsert battery it runs few times if i push switch inside (one activated when gun is pushed against surface), but after few attempts (or if i put case together) same problem. Any advice would be much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Flyer13 Posted August 31, 2021 Report Share Posted August 31, 2021 Do you ever find out what was wrong with it as I have the same issue? Quote Link to comment Share on other sites More sharing options...
wingless Posted September 1, 2021 Report Share Posted September 1, 2021 Welcome to the forum. What happens if the steps defined in the Instruction Manual are followed for clearing a jammed nail? FWIW @Flyer13is is not good form to reply to a dead topic and is better form to create a new topic for the current issue. Quote Link to comment Share on other sites More sharing options...
Mescalito Posted December 17, 2021 Report Share Posted December 17, 2021 On 9/1/2021 at 12:57 AM, Flyer13 said: Do you ever find out what was wrong with it as I have the same issue? Did you found a solution for the problem? Quote Link to comment Share on other sites More sharing options...
