Yeti Posted January 15, 2021 Report Share Posted January 15, 2021 Hi All, I lost the charger for my Ryobi R7SD-L13G cordless drill and I am trying to identify the spec of the power supply. The battery is 7.2V, so the power supply definitely has a higher voltage rating. Here is what I know. PSU Voltage must be greater than 7.2V The DC-in port on the drill is 4mm wide and the DC-in port pin is 1.7mm - so the tip on the power supply would be a 4/1.7mm concentric hollow barrel type tip. Missing Info: PSU output Voltage Amperage Polarity - not sure if it is center negative polarity or center positive polarity. If somebody could send me a picture of the spec label on their charger (for the Ryobi R7SD-L13G), I would really grateful. The drill is in perfect condition and I just want to keep using it for drilling pilot holes. Even a link to the manual would be very helpful. Thanks, Yeti. Quote Link to comment Share on other sites More sharing options...
Thesicillian2002 Posted January 29, 2021 Report Share Posted January 29, 2021 Hi Yeti, Ryobi R7SD-L13G chargers part number is: 5131039358 You can order a replacement from www. cjsinclairltd.co.uk Cheers 1 Quote Link to comment Share on other sites More sharing options...
Michele Posted March 20, 2022 Report Share Posted March 20, 2022 On 1/15/2021 at 11:35 AM, Yeti said: Hi All, I lost the charger for my Ryobi R7SD-L13G cordless drill and I am trying to identify the spec of the power supply. The battery is 7.2V, so the power supply definitely has a higher voltage rating. Here is what I know. PSU Voltage must be greater than 7.2V The DC-in port on the drill is 4mm wide and the DC-in port pin is 1.7mm - so the tip on the power supply would be a 4/1.7mm concentric hollow barrel type tip. Missing Info: PSU output Voltage Amperage Polarity - not sure if it is center negative polarity or center positive polarity. If somebody could send me a picture of the spec label on their charger (for the Ryobi R7SD-L13G), I would really grateful. The drill is in perfect condition and I just want to keep using it for drilling pilot holes. Even a link to the manual would be very helpful. Thanks, Yeti. Hi Yeti. I have the same problem as you, did you manage to get the data you were looking for? If you got them could you tell me? I would be very grateful. Greetings Michele Quote Link to comment Share on other sites More sharing options...
