mariost Posted May 17, 2021 Report Share Posted May 17, 2021 You can watch how to make an easy accessory for your angle grinder. Using the right disc you can easily cut every kind of materials like wood , metal and stone. You can cut for 35 cm length and less than 3 cm thick. You can adjust the angle you want to cut from 0 to 90 deg.You can see the construction and the use here: 1 Quote Link to comment Share on other sites More sharing options...
