mihaso Posted June 14, 2021 Report Share Posted June 14, 2021 Hi, I have a weird issue with my - barely used almost new compressor, and I don't know if it's normal or not. If the tank pressure is higher than regulator output pressure, there is a leak. A constant hissing sound. For example the regulator is set to 80 PSI. The tank is charged to 120 PSI, then slowly leaks. If I turn the knob to 120, the leak stops. If I let it charge all the way up, I have to turn the reglator pressure all the way up to stop the leaking sound. This is not normal, right? Quote Link to comment Share on other sites More sharing options...
