fishnaked Posted September 9, 2021 Report Share Posted September 9, 2021 The only SDS wood bits I can find are a few no-name cheap bits. Are there any good quality SDS bits for wood? Or will I have to buy a drill bit chuck adapter so I can use regular bits in my SDS drill? Quote Link to comment Share on other sites More sharing options...
wingless Posted September 12, 2021 Report Share Posted September 12, 2021 The two common sizes of SDS tools / bits are SDS Plus and SDS Max. Which size is being sought for wood bits? Quote Link to comment Share on other sites More sharing options...
fishnaked Posted September 12, 2021 Author Report Share Posted September 12, 2021 3 hours ago, wingless said: The two common sizes of SDS tools / bits are SDS Plus and SDS Max. Which size is being sought for wood bits? 3/8", 1/2", & 3/4", SDS Plus. Not being able to find anything other than a couple cheap no-name bits, it looks like I'll just have to get the adapter which can be found for $15. Quote Link to comment Share on other sites More sharing options...
wingless Posted September 12, 2021 Report Share Posted September 12, 2021 Nothing that large in diameter for wood in a name brand. Here is a Makita set that goes up to ¼" diameter. 1 Quote Link to comment Share on other sites More sharing options...
Mathew123 Posted September 14, 2021 Report Share Posted September 14, 2021 Makita and Bosch both have drill bits. You can check them out. Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted September 15, 2021 Report Share Posted September 15, 2021 Yes, both of those are good bits. I had a cheap bit a while back and it wasn't worth it but maybe I just got a bad bit. Quote Link to comment Share on other sites More sharing options...
fishnaked Posted September 16, 2021 Author Report Share Posted September 16, 2021 On 9/14/2021 at 8:11 AM, Mathew123 said: Makita and Bosch both have drill bits. You can check them out. SDS Plus wood bits? Quote Link to comment Share on other sites More sharing options...
Mathew123 Posted September 17, 2021 Report Share Posted September 17, 2021 22 hours ago, fishnaked said: SDS Plus wood bits? Yes SDS Plus .. they have whole sets Quote Link to comment Share on other sites More sharing options...
fishnaked Posted September 17, 2021 Author Report Share Posted September 17, 2021 28 minutes ago, Mathew123 said: Yes SDS Plus .. they have whole sets 3/8", 1/2", & 3/4" sizes? That would be great! Can you provide a link? Quote Link to comment Share on other sites More sharing options...
kurtlar vadisi Posted September 19, 2021 Report Share Posted September 19, 2021 On 09.09.2021 at 19:24, fishnaked said: Bulabildiğim tek SDS ahşap bitleri, birkaç isimsiz ucuz bit. Ahşap için iyi kalitede SDS uçları var mı? Yoksa SDS matkabımda normal uçları kullanabilmem için bir matkap ucu ayna adaptörü satın almam mı gerekecek? Hello, you can get the set for whatever you need it for. My friends told me the Dewalt Drill bit set is ok. Quote Link to comment Share on other sites More sharing options...
Altan Posted September 20, 2021 Report Share Posted September 20, 2021 There are some SDS+ Auger wood drill bits from a German brand called CK in 6 Metric sizes only as much as I remember. 12mm, 16mm... SDS+ shank brad point?! First time here I found out about Makita ones, I would not use SDS+ brad point drill bits in these small sizes, they might break easily. I should also say CK is a German brand but their Auger bits seems to be made in Far East (China/Taiwan most probably) Currently none of the well known brands do make their Auger drill bits in Western World, Only quality but expensive Auger drill bits are made by Star-M (Known as WoodOwl in USA and kwb in Europe) made in Japan. Also Fisch makes some in Austria. What I said here is about 1/4" E6.3 hex shank Auger drill bits, if you go for round shank auger drill bits you can find German made FAMAG Auger drill bits but very expensive. 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted September 20, 2021 Report Share Posted September 20, 2021 These Makita SDS+ brad point drill bits are not made of one piece of metal, they are plugged. 1 Quote Link to comment Share on other sites More sharing options...
Mathew123 Posted September 25, 2021 Report Share Posted September 25, 2021 On 9/17/2021 at 7:24 PM, fishnaked said: 3/8", 1/2", & 3/4" sizes? That would be great! Can you provide a link? https://www.makitatools.com/products/details/B-49638 This is on the official site. It has 3/8" and 1/2", you can look if they have 3/4" too.. I think they would be included aswell. I think for Bosch you may have to buy different sets for different sizes. But you may be able to find more information on this on their website.I may be wrong. Also, Altan may be right in saying that they may break. But these are the ones that I have used quiet sometimes(the Makita ones) and have worked well for me. Quote Link to comment Share on other sites More sharing options...
wingless Posted September 25, 2021 Report Share Posted September 25, 2021 @Mathew123, The link provided has straight shank and Pozidriv bits. The OP is looking for name brand SDS Plus shank wood bits. Was a different link intended for SDS Plus bits? 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted September 26, 2021 Report Share Posted September 26, 2021 Quote Link to comment Share on other sites More sharing options...
Altan Posted September 26, 2021 Report Share Posted September 26, 2021 Armeg is a British brand making some SDS+ Auger drill bits, they are good with SDS+ products, Specially some TCT SDS+ chisels (British / Italian made) https://www.armeg.com/Wood-Auger-Drill-Bits-Hexagon-Shank 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted September 26, 2021 Report Share Posted September 26, 2021 Also you do not need to buy any drill bit with SDS+ shank, You can buy any type of drill bit with 1/4" hex shank to use with impact drivers and buy this adapter for SDS+ from Snappy 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted April 7, 2022 Report Share Posted April 7, 2022 A brand called Diager makes SDS+ Auger drill bits made in France. Quote Link to comment Share on other sites More sharing options...
Altan Posted November 4, 2023 Report Share Posted November 4, 2023 Another brand called "Blue Master" has a good range of SDS+ auger drill bits. Quote Link to comment Share on other sites More sharing options...
