Pap344 Posted September 22, 2021 Report Share Posted September 22, 2021 I have a DeWalt Model 303 (wired) sawzall and the blade is stuck in the clamp and I cannot remove it. I removed the screw (part # 99164-06), but the blade is still stuck. Any ideas on how to get the blade out? The blade moves from side to side but won’t come out something is holding it in place still. Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted September 23, 2021 Report Share Posted September 23, 2021 My guess is the pin is still engaged and holding the blade in place since it will move side to side. I believe that has a chuck release on the side where you lift up. If so, take a look to see if it is even engaging the chuck. If not, use a screwdriver and you should be able to push up on the chuck and release the blade. If not let me know. Quote Link to comment Share on other sites More sharing options...
