Tortuga Posted December 16, 2021 Report Share Posted December 16, 2021 The right clamshell insert on my DCV-581H vacuum broke. It's an easy fix and lots of places offer the part listed on the parts list, however they don't fit my machine. I'm currently dealing with the third DeWalt tech and they keep insisting that I have the correct replacement parts but the parts are too small. I need a clamshell insert with a 1 3/4 inch hole pattern. Has anyone found one? Quote Link to comment Share on other sites More sharing options...
Tortuga Posted December 16, 2021 Author Report Share Posted December 16, 2021 Here is a picture of the new clamshell and clamshell insert that DeWalt sent me. According to the parts list, the insert should fit this clamshell. 1 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted December 17, 2021 Author Report Share Posted December 17, 2021 I'm up to about my 4th or 5th service tech and they keep wanting to sent me the replacement parts listed on the parts list. I have tried to explain many times that the parts no longer fit each other. Apparently the case has been redesigned and DeWalt is still sending out the old style inserts. Here is a picture of the clamshell and insert that DeWalt just sent me. The insert is supposed to fit the clamshell but it obviously doesn't. All of the part numbers are correct. It's interesting that the clamshell they sent me is the new design but still uses the same part number as the old design. Quote Link to comment Share on other sites More sharing options...
Paul_Delahaye Posted December 17, 2021 Report Share Posted December 17, 2021 I appreciate this is not the point, and a company like Dewalt should know this before blindly sending the same incorrect parts out to you. By now I'd be thinking about cutting the legs off of the clamshell insert, glueing and riveting it to the clamshell. is that basically the part that latches the bottom to the clamshell? you can even see in the parts there is a slight colour variation. Shame it's not a warranty repair and you could let Dewalt sort out their issue 😉 Chances are they sell so few of these clamshells they won't ever really solve the issue. 1 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted December 17, 2021 Author Report Share Posted December 17, 2021 7 minutes ago, Paul_Delahaye said: By now I'd be thinking about cutting the legs off of the clamshell insert, glueing and riveting it to the clamshell. The legs broke off the original insert so I drilled the broken insert and used a couple of small bolts to remount the old insert back in place. It's functional but the bolt heads interfere with the clamp. DeWalt has decided to send me another clamshell and insert. Eventually they will run out of the old style inserts and I'll get one that fits..🤣 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted December 17, 2021 Author Report Share Posted December 17, 2021 This is my temporary solution, however it's very difficult to open the clamp because the top of the clamp slides up and hits the bolt heads Quote Link to comment Share on other sites More sharing options...
Tortuga Posted December 29, 2021 Author Report Share Posted December 29, 2021 On 12/17/2021 at 12:12 PM, Tortuga said: DeWalt has decided to send me another clamshell and insert. Eventually they will run out of the old style inserts and I'll get one that fits..🤣 I received the new clamshell and clamshell insert from DeWalt. They don't fit each other, they look exactly like the last set that DeWalt sent me. DeWalt has an obvious manufacturing problem that is not being addressed... Quote Link to comment Share on other sites More sharing options...
Tortuga Posted January 8, 2022 Author Report Share Posted January 8, 2022 The last service tech that replied to my email finally suggested that I call the parts department directly. The guy at the parts department looked at the email and images that I sent and instantly understood the problem. Why didn't the 5 service techs do that? Who knows... Anyway, the parts guy promised to track it down and give me an answer answer. 👍 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted January 14, 2022 Author Report Share Posted January 14, 2022 So I called the DeWalt Parts Department again (888-678-7278) and the lady that answered this time insisted that I take my vacuum to a factory service center. I tried to convince her that there isn't anything on my vacuum that the pictures don't already show. I told her that anyone could go into their warehouse and get the two parts that are supposed to fit each other and see for themselves that they don't fit. She insisted that I call the Factory Service Center in Utah (I'm in California) because they have the parts and could look at them. She put me on hold to get their number but when she came back she told me that she had looked at the pictures that I had uploaded. She forwarded them to her supervisor and the supervisor was going to contact the main parts warehouse. Then it was, don't call us, we'll call you. So I don't know if this is progress or not..🤣 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted February 17, 2022 Author Report Share Posted February 17, 2022 I have called and emailed DeWalt several times after they sent me the "Don't call us, we'll call you" email. Here is the answer I received today. "This is the answer that I received back from the warehouse: The pictures you sent match exactly what they had in stock and this was the correct part. They said there was a change made at some point and they don’t have the original style. It was suggested that we send you a replacement different unit since the original inserts are not available anymore. We can send you the model number DCV585T2. If it is okay with you for us to send you this unit, please respond back to this email. We apologize for any inconvenience." 👍😁 Quote Link to comment Share on other sites More sharing options...
Paul_Delahaye Posted February 18, 2022 Report Share Posted February 18, 2022 If I was Dewalt customer services I think I would have made this suggestion a couple of months ago! lol to think what it is costing them trying to work this out, giving you a new vacuum is a much more cost effective solution 😉 1 Quote Link to comment Share on other sites More sharing options...
Tortuga Posted February 22, 2022 Author Report Share Posted February 22, 2022 On 2/18/2022 at 7:44 AM, Paul_Delahaye said: If I was Dewalt customer services I think I would have made this suggestion a couple of months ago! lol to think what it is costing them trying to work this out, giving you a new vacuum is a much more cost effective solution 😉 I asked them for a replacement several times and offered to return all of the parts they sent me plus my old vacuum. I would have been happy to just have a new DCV581H and they could have everything else. Now I have my DCV581H that I modified so it's usable, several clamshells and clamshell inserts that I don't need and a new DCV585T2 that I really don't want... Quote Link to comment Share on other sites More sharing options...
